Results 1 to 2 of 2
    Jan 2014
    Default audi a4 2004 2.0I vacum nad camshaft problem
    He!
    I needs help from error code like in photographs..
    not yet I inspected the installation but powering to the Vacum sensor and camshaft is correct. Exchanged ecu and sensors vacum and camshaft.
    a Vacum pump which was listed was damaged on new and is acting correctly.
    Where else apart from wiring up can a problem be?
    Dziwak's Avatar
    Jun 2014
    UK
    99% wiring fault.. common the plastic grommet rubs on the loom cuts the plastic insulation and wires corrode from inside
