Results 1 to 5 of 5
    Sep 2015
    Default MMI 3G - red screen
    Hi!
    My friend recently bought a 2010y audi A6. And today he tried to update his unit in according to install new map (from 2017). Something goes wrong in this process and he ended with bricked unit. It's not cheap. But I searched ethernet and found a pdf that describing how to repair this unit ( https://pl.scribd.com/doc/225614389/How-...r-3G-Plus) if this is software fault.
    And this should be soft problem, since:
    Unit is turning on, green screen for a half second with:
    MMI3G EmApp 22.30.1642
    Starting up.
    Scan metainfo
    Please wait
    And then red screen:
    MU9307
    Trigger to shutdown in 53 sec!
    Mount error
    Update failed! Trigger shutdown after countdown...
    We downloaded few firmwares from many sites and unpacked them on SD card. (one is version 0031_3 with 1,2,metainfo2 ; another one is 0257_6 with 1,2,3,metainfo2 and many versions between them), since I tried to just give unit the source. Because I think it only need a source to update.
    But none of this works. Only change is that when SD card is inserted there is no "Mount error" but "Metainfo CRC error".
    Any help? Any advice?
    Jan 2010
    Pilica
    Solved problem ??
    Apr 2010
    Usa
    how you solved?
    please tel us.
    Thank you
    Nov 2017
    Czech republic
    HI
    how you solved?
    please tel us.
    Thank you
    Mar 2015
    guys, you know what i want ask you
    solution ?
