Results 1 to 11 of 11
    mislav88's Avatar
    Mar 2011
    Default PCR 2.1 start stop off
    Can someone please disable start stop in this file?
    I had error about neutral position sensor, disabled it but still start stop error on dash.
    Tried coding and adaptations with vcds but still no luck.
    Hope software solution with solve it
    Nov 2016
    Did you find a solution? I looking for one myself.
    Sep 2016
    vcp and procedure, thats all.
    FILE SERVICE
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    I donīt know if itīs work but on long coding on ecu with vcds (maybe also VAG CAN) you have option for start stop take a look
    press thanks and reputation if itīs helpful
    Meat-Head's Avatar
    Quote Originally Posted by voltechcar View Post
    can you say that again please for folks of lower intelligence
    Sep 2016
    use vag can pro, this tool have automatic procedure which turn off start stop, no need modify software.
    FILE SERVICE
  7. The Following 3 Users Say Thank You to voltechcar For This Useful Post:
    AVDigitale (23rd September, 2018), Meat-Head (23rd September, 2018), morgano (24th September, 2018)
    rfernandes's Avatar
    Jun 2018
    portugal
    True......
    Dec 2016
    i have VCP and it has automatic procedure to disable start stop but which procedure you use for VW Polo 6R 2012 yera PCR2.1 1.6 TDI 90HP CAYB?
    I try all of them and errors
    >>Genuine Winols, Swiftec, Ktag, Flex, x17<<
    >Diagnostic, Chiptuning, Dashbord<
  10. #9
    Apr 2011
    Quote Originally Posted by kubuswujo View Post
    Post your file, can be disabled in flash.
  11. #10
    Junkyard Dog's Avatar
    Mar 2019
    EUROPE
    Do you trying with VCDS too?
  12. #11
    Carli's Avatar
    Dec 2020
    Everywhere
    Done a lot by editing in "flash" without problem. But if u have VCDS you can try.....
    The steps to disabling start-stop system:
    1. Enter 19-CAN Gateway
    2. Click on Coding-07
    3. Click on Long Coding Helper
    4. Change Byte 3, Bit 2-3 (Drop down menu) from 04 Start/Stop System with Recuperation installed [PR-7L6] to 08 Start/Stop System NOT installed [PR-7L3]
    5.Change Byte 4, Bit 0 to 0
    6.Change Byte 15, Bit 0 to 0
    7. Click on Exit - top left hand corner
    8. Click on Do it!
    If this help you, tnx + rep
