Results 1 to 11 of 11
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Default ....
    hi. can anyone please share pinout for this ducati dash 24c02 eeprom is 5pin smd type. not regular 8 pin.
    Aug 2016
    don't edit mileage because dashboard will show ----- on lcd
    drugowaz's Avatar
    Mar 2015
    Lithuania
    i need only pinout for this chip . for key making. cant find anywhere 24c02 pinout for this 5 pin chip. can anyone post correct pinout for this dash?
    drugowaz's Avatar
    Mar 2015
    Lithuania
    and advice how to open dash case securely as it is glued
    drugowaz's Avatar
    Mar 2015
    Lithuania
    still need info. this dash is glued?
    how to access to eeprom? anyone done this dash?
    fixanycar's Avatar
    here
    Did you get it done? My friend had 2016 model, don't know if he programmed it or not,.. no information on transponder
    Sent from my XT1650 using Tapatalk
    drugowaz's Avatar
    Mar 2015
    Lithuania
    transponder 80 bit. info i need how to open dash case. its glued totaly.
    Mar 2014
    West Sussex UK
    Is this the MAE Electronis dash you have? If it is keys are not in eprom but in pic18f6585
    drugowaz's Avatar
    Mar 2015
    Lithuania
    in pic is up to 2013 . from 2013 its in eeprom.
  10. The Following User Says Thank You to drugowaz For This Useful Post:
    Cromwe11 (20th September, 2017)
  11. #10
    Apr 2014
    Only TMPRO2 with module 189
    Sent from my SM-G930F using Tapatalk
  12. #11
    Mar 2014
    West Sussex UK
    Quote Originally Posted by trinicolin View Post
    Also a script available for this on Iprogplus
