Good Luck!
Good Luck!
Truan21 (29th August, 2017)
Hi. Thank you firstly. The second I put the eeprom. And all correct. But when I give the lights it stops working everything. Everything in orange does not work or revolutions. Neither velocimetro nor anything. And already the picture does not come back to revive, if I put again original eeprom the picture goes perfect, maybe this is not well modified the eeprom? Thank you
dump from jomberykaso is good
you can give this a try
Truan21 (30th August, 2017)
I will try this last file. I like it more since the last row also changes it. And the series has changed. I put it and hosn cuento. Thank you for helping everyone.
Hi. Sorry for the delay I got the eeprom you passed me but it does not work. appears "error" any proposal? someone has any doubts and is sure that it works? Thanks to all for the help
Enviado desde mi SM-N9005 mediante Tapatalk
Put original file back and see if it still works that way!
yes. the original works. I put original archigo and everything well. I put file changed by digiprog 3 and todonok until I give lights and everything in orange and nothing works. I have the file last file that I have passed and "error" I put original file and everything ok. any solution?
Put this file and reportAttachment 472842
Truan21 (21st September, 2017)
Hi. "Error" :$
What programmer are you using to write mod file ?
digiprog 3. I'm going to try to get the file out of the old box and put it in the new one if I get it hos file and host comento. Thank you
you desoldered the eep ?
Yes
