Translate in normal language, everybody of us has to fight with them each day to get what he has paid for...
We should also make business with them, when server not answer right now... Press PayPal dispute buttons... And all at the same time...
rob h (20th September, 2018)
I don't know about the extra tokens, but if you get 1 token each day and you have to reactivate every 180 days, then you should contact CGDI or your beloved dealer and make them fix this and put you on one of the existing plans - A or B.
This extra tokens for additional tools seems too shady, still. It should be explained separately what happens if you have plan A and get a second machine, and if you have plan B and a second machine.
figani (21st September, 2018)
for them it´s shady OK... so they can tell you one story and me another story...
1000 of coustmers and 1000 of storys...
the shit will start to smell when the server get not enough electricity...
After newest update tried to renew med17. 7 and could not do it. It worked before
Sent from my SM-G950U using Tapatalk
yugo45 (22nd September, 2018)
CG-MB BenzMonster V2.7.2.0
(2018.09.20)
1. Fixed the problem that read EIS failed when 209/211 collection with key.
2. Fixed the problom that 209 sync ELV and 169 write ELV display is not clear.
3. Fixed the problom that the K-line EIS is enabled successfully, but the display fails.
http://www.cg100iii.com/benz/BenzMonster_Setup.exe
How do we know what models it can do by obd and what models we need to do on the bench? C250 2013 can we add key by OBD? Can it do all keys lost OBD on this model? Thank you.
hello
is there a problem with new update for w204 AKL, it is always failing
yugo45 (28th September, 2018)
yes and W212 too it keeps failing to add key, when it is supposed to save the collected file for password computing it always asks it i inserted the working key on the EIS
dont think will ever be as good as vvdi
CGDI Can add the original bga key?
yes , in fact i used to have the vvdi , recently bought the cgdi , it cant get all passwords for 7g , also
today i tried w203 this time it was able to add key without removing the EIS from the car and car key was nec one , it took around 20 mns
