Page 109 of 172 FirstFirst ... 95999104105106107108109110111112113114119159 ... LastLast
Results 1,621 to 1,635 of 2578
  1. #1621
    Feb 2014
    1 - sounds like a faulty ELV. Do you have a way to confirm it is working? ALso check if the key status says "Activated".
    2 - try to put new batteries. Or use higher quality keys.
  2. #1622
    p1et's Avatar
    Oct 2013
    NEC .081 can't reset today, tried like 30 times... Read is always OK
  3. #1623
    p1et's Avatar
    Oct 2013
    Can someone check in other device which key positions are free and which ones are used? AKL and I don't want to overwrite lost key.
  4. #1624
    Used 0 and 1
  5. #1625
    Oct 2017
    Quote Originally Posted by autoTkey View Post
    I'm with you on thee key issue but the elv is good because i have a working key and everything works on that one except the remote. I tried 2 keys a used oem Key and a cheap Chinese eBay key both of them have me the same result.
    Sent from my SM-N950U using Tapatalk
  6. #1626
    please i need pass for w203 ecu a111 4cyl , special key - 6E 5D F1 2E 14 65 E7 28
  7. #1627
    Aug 2010
    Quote Originally Posted by abdulrauf View Post
    Here is your Erase Pass:
    Jonny
  8. The Following 3 Users Say Thank You to jonny r For This Useful Post:
    abdulrauf (3rd October, 2019), ficho (3rd October, 2019), taxo1965 (11th October, 2019)
  9. #1628
    p1et's Avatar
    Oct 2013
    Sometimes happens because the tool IR is not as good as the Benz IR in the car. Did you try to read without the key shell? It may help.
    No I didn't try read key without shell but I don't think it would help as IMO this is software bug. I never had problems with reading original NEC keys via IR, no single problem before.
  10. #1629
    Feb 2014
    Well there's a first for everything. It happens sometimes - I experienced it. It happens mostly when the key shell has been replaced and is not the original and also when dust and dirt builds up inside.
  11. #1630
    Oct 2016
    France
    hi,can cgdi make key on vito 2012?
  12. #1631
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by barho67 View Post
    Yes, no problem...
  13. The Following User Says Thank You to figani For This Useful Post:
    barho67 (4th October, 2019)
  14. #1632
    Apr 2019
    Hi all,
    I need erase pass for ELV W204. I tried with CGDI but not success. This is the file: https://mega.nz/#!yxc13Yba!DjqwHQZT1...REDGE3i2lsGBGU
    Someone can help?
  15. #1633
    Aug 2010
    Quote Originally Posted by niksata90 View Post
    Hi all,
    Someone can help?
    Post your Special Key (Sonder Hash) and i will calculate Erase Pass for you
    Jonny
  16. The Following User Says Thank You to jonny r For This Useful Post:
    niksata90 (5th October, 2019)
  17. #1634
    Apr 2019
    Quote Originally Posted by jonny r View Post
    Jonny
    14 83 46 A3 76 CA 0B F4
    Thank you!
  18. #1635
    Aug 2010
    Thank you!
    Jonny
  19. The Following 2 Users Say Thank You to jonny r For This Useful Post:
    ficho (6th October, 2019), niksata90 (6th October, 2019)
