lion0304 (21st November, 2017)
Bad new from CDGI, reported by many users who trying Key lost W204 W207
Bug came when collect data at 100%
This bug did not exist under SW 1.5
Adding key succes by user on Sprinter W906 2010 with BGA key
On car and by OBD.
lalaina74 (23rd November, 2017), p1et (22nd November, 2017), whiskeyman (22nd November, 2017)
all by ir?????
obd?
Just tested, after you make data collect, upload to get PSW, and key calculation, you can use any position key
Even this position is already USED. Key write with used position work no problem.
So if you have exiting key, check it first what is the position track before writting new key. Just all.
Also if you have dump with PSW, just load on server and calculate key, no need use SKC. This calculation, you can use 10 by day.
Please stop misleading people!!!!! You have absolutely no idea how FBS system works.........Even this position is already USED. Key write with used position work no problem.
Guided fault finding = Feature that many factory scan-tools have and real technician despise it.
Take away your ego, do you have some problem with your neck? Because your ego is more bigger than your head and your mind.
Yes i don't know many about FBS, but i've just made my own experience today, write new key in used track key. And it WORK.
And post what and why it cannot be? So we can compare your words with my video doing what i said
Generally there shouldn't be a problem with adding a key over a used position. Just the old key will not work anymore.
But sometimes car doesn't accept a key over a used position so it's a safer bet to disable the unwanted used positions and program the new key to an UNused position...
By logic, when you have exiting key and you want to write new in used position (because no free position anymore), so you need check first your exiting key use in what position.
CGDI give info that what last key is used in EZS.
Key generate by CGDI dont write used key, all as like new (even in used position, track)
And sure when you write new key with used exiting key, the new work and other stop working.
Benz not allow 2 key work in the same position.
What I said is valid for all MB tools. No need to repeat it again.
Still sometimes car doesn't like this for some reason and key is not accepted.
daxxer (22nd November, 2017)
I dont have other tool,
I dont talk about special case that car does not accept.
I dont talk about something i don't know, not see yet
I talk just my experience i've just did.
I'm just nothing compare to all the world
I don't say that what i write, what i do it's the true evidence for all.
igorr (22nd November, 2017)
OK. Man, no need for this defensive position. I'm just adding to your words...
I receive tool today.
Made spare key on w211 in 3 minutes.
Got pass from ezs direct with simulation key...
Very fast !!
autoTkey (23rd November, 2017)
