Yes.........
Yes.........
trunggt2007 (27th October, 2018)
When we need to use gateway to read an eis on bench which gateway do you use? I'm assuming it's the small box one right?
https://www.aliexpress.com/item/Newe...821388606.html
Or
https://www.aliexpress.com/item/For-...819566004.html
All key lost w164 works by obd ?
Is it possible to calculate the password for W210 EZS when the key is big old motorola?
Best Regards
Yes
If key is working key for Eis you can read mcu and post here to get
key password read Eis and post key password and generate keys.
papalos_ (31st October, 2018)
yes, I did it once
is anybody which used xhorse black esl emulator with cgdi mb ? I tried to use it for W204, followed manual but under menu "esl-simulator" i was not able to read or erase this emulator, all time got message : fail to read or fail to erase simulator. Finally directly load eis file , write it successfuly and was warned to put original key in eis to activate esl; ignition on, car start normally but if i read again, esl appear that is not personalised and activated....is anybody which had same experience ?
Thank you !
i have cgdi mb it can't connect to server
what is the problem please
figani (1st November, 2018)
this looks like a good tool for me, who cannot do any MB at present,
i see it lets 1 key per day for free, is this one password calculation, so if calculation needs to be done again, it charges?
also is there a list of mercedes cars it can do by OBD? i can find a list but it surely is wrong because it says even most recent MB can be done
Tried to make a spare for a w209. Read eis, went to collect key data and read in eis, then asked to put in CGDI but wouldn't read the key. Tried multiple times, just hangs. Tried to connect dc 12v but didn't help. Key reads fine under read key tab. This was the black style fob. Any ideas?
comizelu (8th November, 2018)
