ioanrokos (14th November, 2017)
W221 2008 with key v57 from Japan:
Add key success after 30mn, get PSW in the 2è upload.
He said VVDI or Diagspeed need usual 1 or 2H for that.
p1et (15th November, 2017)
It will work, I'm sure. There are no such thing as keys ONLY for VVDI.
H.Wessel - something's not right. Why don't you try to renew your original key and write it to a fresh position? Then you will know if it's the keys or the dump. In my opinion it should be the dump.
Another way is to read the dump by eeprom. Then you will have a 100% sure backup in case something goes wrong. And you will be sure that the generated key dumps are correct.
Also keys cannot be wrong - they are compatible with all cars. Especially those from Autokeys. Some of them have the problem of corrupting the data over time but never failed me on the first start. And I have bought a lot from autokeys.
Another piece of advice - I have noticed when you renew a BE key it actually is still operational on the car, unless you write another dump to it. So this could be a reason for a problem when, for example you program the key initially over a used position(like first or second) and for some reason it's not OK. Then you renew and program to position 3 but still doesn't work. To make it work you have to renew, then write dump from another car or from an empty key, then write the correct dump for this car.
H.Wessel (15th November, 2017), ioanrokos (15th November, 2017), whiskeyman (15th November, 2017)
kevfield (15th November, 2017)
lion0304 (15th November, 2017)
W221 2010 Facelift Work too
https://youtu.be/NFEj21fd8WQ
mikajna (16th November, 2017)
Just did some minutes ago ML350 W164 2006
Read EZS, add key, write BE key all done in 17mn.
Really fast and i'm happy with the first try on car.
Use late software 2.0.0.0
how you read
when i tried mll350 i could not connect to ezs same year
2007 w221 from Japan: Add key on bench
First try i use vvdi
But 2 time upload also failed cannot get pass
So i was change device Cgdi from vvdi
1 time upload successful
Good and very fast 10min got pass
doctore (17th November, 2017), ioanrokos (17th November, 2017), mikajna (18th November, 2017), speedservice (5th May, 2018), whiskeyman (17th November, 2017), yugo45 (17th November, 2017)
Today add Key on W221 2007
i was complete in ~12min
CGDI is very fast
Upload collect data after 2 or 3 min show me PW
doctore (17th November, 2017), lion0304 (18th November, 2017), whiskeyman (17th November, 2017)
Class C W203 2005 adding key on car.
Spare key made in under 10 minutes.
