Results 1 to 15 of 18
    audiotek's Avatar
    May 2011
    Default 2016 Nissan March 28556-9LJ2A with 95128 eeprom crash reset
    Hi, I need your help to reset this airbag module:
    2016 Nissan March
    Airbag Module: 28556-9LJ2A
    Eeprom: 95128
    Here is the crash file, thanks in advance:
    Xprog Box Original, UPA Original, GromCalcTool,TL866A, Willem PCB50, Masterprog, NecProg, Orion, Ponyprog, Carprog, Renesas H8SX, MT60/80, SPC560 programmers,Obdstar X300DP, EZ500, CHIPSOFT MID,SKP1000,Cantool, SuperVag 3.0, Vag Commander, Vagcom Original, Launch x431 Pad, Witech OEM, Ford VCM II OEM, Mazda VCM II, Volvo Vida-Dice, Hyundai & Kia GDS, MUT III, Mastertech VCI, EASE j2534, Ford & Mazda VCX, TS401, Cardaq-m, DIS 5.7, VAS5054 Plus, Tachopro 2.0 & 2008.01, Vag K+Can, JLR v141.....
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Hi friend, your cleared file, report back.
    BR
    Dragon
    Best regards.
    Dragon
  3. The Following User Says Thank You to dragon100 For This Useful Post:
    audiotek (12th September, 2017)
    audiotek's Avatar
    May 2011
    Quote Originally Posted by dragon100 View Post
    BR
    Dragon
    Thanks friend but doesn't work: No communication.
    dragon100's Avatar
    Jan 2012
    Sorry friend, I will try again ...almost my clear work, but life is life , na na na na na ...
    Best regards.
    Dragon
  6. The Following User Says Thank You to dragon100 For This Useful Post:
    audiotek (13th September, 2017)
    audiotek's Avatar
    May 2011
    The problem for no communication was the eeprom, xprog says "bad contact in pin 7" I replaced the eeprom and now have communication but retrieves DTC B1428 (internal unit). Let me try your new clear...
  8. #6
    audiotek's Avatar
    May 2011
    It is not the same pass? I can't open the file.
    I found the pass, sorry
  9. #7
    audiotek's Avatar
    May 2011
    Now is working, Thanks for your help....
  10. The Following User Says Thank You to audiotek For This Useful Post:
    dragon100 (13th September, 2017)
  11. #8
    Nov 2017
    hola amigo. Tengo un shock detectado en un módulo igual. ¿Me puede dar el código de acceso del archivo por adelantado? Muchas gracias
  12. #9
    Nov 2017
    Default friend hello I have a detected shock in an equal module can you give me the access co
    [QUOTE = dragon100; 3103486] Lo siento amigo, intentaré de nuevo ... casi mi trabajo claro, pero la vida es la vida, na na na na na na ... [/ QUOTE]
  13. #10
    dragon100's Avatar
    Jan 2012
    English please, mate ...
    Best regards.
    Dragon
  14. #11
    Jul 2016
    bogota
    dragon por favor me regala la contraseña gracias
  15. #12
    May 2018
    MEXICO
    HI SORRY can you give me the access NISSAN MARCH WHAT IS THERE TO DO I AM NEW AT THIS FORUM
  16. #13
    Cllau's Avatar
    Mar 2017
    where friends need me
    Quote Originally Posted by ernani View Post
    read Eeprom 95128 and post your dump here......
  17. #14
    May 2018
    MEXICO
    HI CLLAU NISSAN MARCH RED EEPROM
  18. #15
    May 2018
    MEXICO
    Default help
