Your file
Pass in PM
Your file
Pass in PM
kubuswujo (13th September, 2017)
Hi!
Everyone this mod is from MPROG is not working.... The Auto does not start....
when I write an orginal file once more then its starts normally....
Can someone edit oryginal file on MAX performance or can You MProg repair it?
try this....
kubuswujo (15th September, 2017)
DSG TUNING
File Service
I used last time MPPS (I now it is old kable) but have also Galleto and Kess and KTAg EU
Im shure galletto make chks for this.
Wysłane z iPhone za pomocą Tapatalk
DSG TUNING
File Service
sorry guys I am an idiot i have given here the bad oryginal ECU file to Edit...
good file in the attachment.
and the ECU is:
Bosch Hardware nr. : 1037390517
Bosch Software nr. : 0281014643
Opel software nr. : 9807415
Engine type: Z17DTH
Art1703 (5th August, 2018)
here is your new file
the same pass
Hi!!
The file does not work but i think the problem is OBD Connection i used MPPS and then Can write mod and if not working than write oryg.
Then have used Kess OBD and on the and of writeing get "writing error" since then i cannot write oryg via OBD using KEss or MPPS.
I have this auto earlier and also got this problem.
And can only write it VIA BDM K-tag so can someone edit an BDM Flash? ON MAX Performance?
A s I see on this vehicle I can only Edit flash without errors using BDM, OBD is not working.
The oryginal BDM flash is in atachment fls(1)
your bdm file
the same pass
obd read in this car its not good to tune because its not all maps to modify, only full bdm and tune to this file. G54 good write full bdm to obd.
FILE SERVICE
kubuswujo (20th September, 2017)
Probabably You are right. But this vehicle is very bad eletrical condition do not know what but sometimes connect with OPCOM sometimes not. Aslo before chip.
@Johak there is no file in your post, (You have edited it) Can You post it again?
I read/write this ecu only in bdm because in obd is bad...
Hey thank You Very much this BDM file from Johak is working very well. And rally had the Power
