Page 1 of 2 12 LastLast
Results 1 to 15 of 17
    Dec 2016
    Poland
    Default Opel Astra III 1.7 CDTi 2007 MaX Performance CHIP
    Hi!
    Please make a Max Performance CHIP For
    OPEL ASTRA 1.7 CDTI 101 KM 2007
    Max performance in my opinion will be 130-135 KM.
    Thanks in advance
    Kuba
    mprog's Avatar
    Feb 2017
    Europe
    Your file
    Pass in PM
  3. The Following User Says Thank You to mprog For This Useful Post:
    kubuswujo (13th September, 2017)
    Dec 2016
    Poland
    Hi!
    Everyone this mod is from MPROG is not working.... The Auto does not start....
    when I write an orginal file once more then its starts normally....
    Can someone edit oryginal file on MAX performance or can You MProg repair it?
    johak's Avatar
    Apr 2010
    try this....
  6. The Following User Says Thank You to johak For This Useful Post:
    kubuswujo (15th September, 2017)
  7. #5
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    Quote Originally Posted by kubuswujo View Post
    Hi!
    Maybe Your tool doesnt make chks...
    Mprog make great tunes, im shure.
    Wysłane z iPhone za pomocą Tapatalk
    Chiptuning - Diesel / Petrol / Stage1,2,3 / HIGH Petrol Tuning
    DSG TUNING
    DPF / EGR / TVA / SAI / Lambda
    Crackle map ( Launch Control + No lift Shift + Antilag )
    File Service
    PCMFLASH / BFLASH / AMT BST / AMT MPPS / TGFLASH / BITBOX / EDCSUITEPRO - Genuine USER
  8. The Following User Says Thank You to maajkii For This Useful Post:
  9. #6
    Dec 2016
    Poland
    I used last time MPPS (I now it is old kable) but have also Galleto and Kess and KTAg EU
  10. #7
    maajkii's Avatar
    Mar 2017
    Im shure galletto make chks for this.
    DSG TUNING
    File Service
  11. #8
    Dec 2016
    Poland
    sorry guys I am an idiot i have given here the bad oryginal ECU file to Edit...
    good file in the attachment.
    and the ECU is:
    Bosch Hardware nr. : 1037390517
    Bosch Software nr. : 0281014643
    Opel software nr. : 9807415
    Engine type: Z17DTH
  12. The Following User Says Thank You to kubuswujo For This Useful Post:
    Art1703 (5th August, 2018)
  13. #9
    johak's Avatar
    Apr 2010
    here is your new file
    the same pass
  14. The Following 2 Users Say Thank You to johak For This Useful Post:
    Art1703 (5th August, 2018), kubuswujo (19th September, 2017)
  15. #10
    Dec 2016
    Poland
    Hi!!
    The file does not work but i think the problem is OBD Connection i used MPPS and then Can write mod and if not working than write oryg.
    Then have used Kess OBD and on the and of writeing get "writing error" since then i cannot write oryg via OBD using KEss or MPPS.
    I have this auto earlier and also got this problem.
    And can only write it VIA BDM K-tag so can someone edit an BDM Flash? ON MAX Performance?
    A s I see on this vehicle I can only Edit flash without errors using BDM, OBD is not working.
    The oryginal BDM flash is in atachment fls(1)
  16. #11
    johak's Avatar
    Apr 2010
    your bdm file
    the same pass
  17. The Following 2 Users Say Thank You to johak For This Useful Post:
    Art1703 (5th August, 2018), kubuswujo (20th September, 2017)
  18. #12
    Sep 2016
    Poland
    obd read in this car its not good to tune because its not all maps to modify, only full bdm and tune to this file. G54 good write full bdm to obd.
    FILE SERVICE
  19. The Following User Says Thank You to voltechcar For This Useful Post:
  20. #13
    Dec 2016
    Poland
    Probabably You are right. But this vehicle is very bad eletrical condition do not know what but sometimes connect with OPCOM sometimes not. Aslo before chip.
    @Johak there is no file in your post, (You have edited it) Can You post it again?
  21. #14
    Dec 2015
    Romania
    I read/write this ecu only in bdm because in obd is bad...
  22. The Following User Says Thank You to ionutdanica For This Useful Post:
  23. #15
    Dec 2016
    Poland
    Hey thank You Very much this BDM file from Johak is working very well. And rally had the Power
