try with this pogram
Hi Folks.I heave problem with Abs module in touran 2004 1.9tdi with dsg.I can't solve this error:
Component and/or Version: ESP FRONT MK60 0103
Software Coding: 0021190
Work Shop Code: WSC 01324 785 00200
VCID: 3A7F36DB0E9F
1 Fault Found:
01044 - Control Module Incorrectly Coded
008 - Implausible Signal
I've made some coding and couple attempts to basic setings but no succes.Is there some special procedure for this error?
Please dear members push the button if my work was helpfull!
And reputation button(star)
drewdom (15th September, 2017)
Thanks but I think here is not long coding.This is MK60 not MK60EC.My ecu nr:
ESP FRONT MK60 0103
hello how did you solve this problem?
is a post from 2017 mate.......
electrons (18th May, 2023)
If I remember correctly coding was ok but all dumps in abs,ecu and dash has to be from the same car. I think the best way is flash with odis online al this modules and dsg to.
post your request here , we will help you
MK60 ABS Long Coding for DK members (digital-kaos.co.uk)
