DSG TUNING
File Service
try and report, pass in pm
03G906021CF _SW9946_dataareaVW_EOS_BMM_2006.zip
naighba (18th September, 2017)
i send file error
this is your file 03G906021CF _SW9946_DATAAREAVW_EOS_BMM_2006 MOD.rar
woow . you tested file in tis car majiki and 0soinsa
Thanks for the fast reply. You used a map from similar engine ?
Does any of you know if this is flashable with VagCan Pro K+Can ?
Nope, i make file for you. Every car is different.
Wysłane z iPhone za pomocą Tapatalk
DSG TUNING
File Service
Comming back with news after 1500km. Tested @maajkii maps and everithing ok untill now. Car is more responsive. I can feel a slight boost on power. Is way better than stock anyways. On the fuel consuption side there are no obvious changes.
Will test @0soinsa maps when time allows as it takes me 1 hour to upload the ECU
Thank you both again !
Hy to all ,can somebudy please help with a ori file for a VW Golf 6 2010 2.0 Tdi , Kess V2
I don't have my file , my car got updated by vw , and tuning lost, now ecu has TP, I have to open it , patch with k tag and the open to flash but I am testing now protocole 501 and I need a ori file , just to test if TP ecu can be whriten on obd direct, if all ok don't need anymore to open some ecu!
Protocole 501 should buypas Tp rot by whriting!
Trimis de pe al meu SM-G930F folosind Tapatalk
Hello, can i ask you pass? thx
