Thread: TDV6 engine
    V.I.P. VIC
    Mjolinor's Avatar
    Jan 2009
    Burnley Vicshire
    Default TDV6 engine
    Would anyone like to tell me what this engine is fitted in. I have one from a Land Rover Discovery that has broken the crank and need to find one so I can mend it.
    Jag use it. Is the Vectra the same engine?
    Any others?
    Aug 2010
    Have a look here lots of information http://engineengineering.co.uk/start/
  3. The Following User Says Thank You to ascouser For This Useful Post:
    Mjolinor (18th September, 2017)
    Sep 2010
    Engines are Ford/Peuegeot and completely unreliable with failures and design faults like that are very common. The issue probably here is that the bearings have spun & ruined the crank which can happen even at very low mileage. Kits available on internet eg Ebay. Engines found in Jag S type, XJ, XF, Discovery 3, Range Rover, Peugeot 407, 607, Citroen C5, C6 if looking for a short motor but I wouldnt want to guarantee anything as they are troublesome. Either way it will probably cost a couple of thousand pounds in parts, give you a big headache sorting the issue and you can do the whole job again soon after as its going to go wrong again.
  5. The Following User Says Thank You to testune For This Useful Post:
  6. #4
    V.I.P. VIC
    Mjolinor's Avatar
    Jan 2009
    Burnley Vicshire
    Thanks for the input.
    The crank is broken. This is currently an assumption based on the fact that you can wobble the nose of the crank where it comes out of the oil pump.
    It does seem to be a truly crap design of engine, the sad thing is that I know one of the guys that designed it.
    norfolk uk
    Beware Peugeot 407 and citroen c5 version of this engine will not fit in jag/landrover as the bellhousing is different although heads and crankshaft appear the same
  8. The Following User Says Thank You to shadow12 For This Useful Post:
    bonecrusher (19th September, 2017)
  9. #6
    Meat-Head's Avatar
    Quote Originally Posted by Mjolinor View Post
    Well name and shame him, then get him to fix it, then smack him riund the face with a wet fish
