    DK Veteran gtmech's Avatar
    Hell
    Default Transit SID208 DPF OFF
    Hi Guys, is anyone able to assist with a DPF OFF for this 2013 Ford Transit SID208 ECU? Any help with this is greatful, thanks
    raskolnikov1975's Avatar
    EU
    No pasword..Try and report..Dont forget rep and thanks
  3. The Following 6 Users Say Thank You to raskolnikov1975 For This Useful Post:
    danyguit2000 (24th July, 2020), fronzethenight (20th November, 2017), gtmech (18th September, 2017), mot 1 (5th September, 2023), n599fbm (4th December, 2018), vitorponte (30th June, 2020)
    Hell
    does anyone have a working solution for this?
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    hmm... wird...
    i make around 5-6times this ecu i use always same solution like raskolnikov1975
    and it works fine for me... any dtc codes? you reset dpf values before flash?
    regards.
    DSG TUNING
    File Service
  6. The Following User Says Thank You to maajkii For This Useful Post:
    gtmech (20th September, 2017)
    Hell
    Quote Originally Posted by maajkii View Post
    hmm... wird...
    regards.
    raskolnikov1975 solution works for DPF OFF but DTC says ecu eeprom software fault. Why need toreset dpf values before flash? No i havent done that and havent touched the checksum either, please explain more about that, this is my first DPF problem so not much experience with them at all
  8. #6
    Jul 2014
    Quote Originally Posted by raskolnikov1975 View Post
    this is not good file
    in this file deleted many DTCs
    dtc Rail sensor Camshaft sensor Cranckshaft sensor etc.........
