try this
best regards
Hello guys,
I have this Toyota Alphard Van, it has a valet 4c key,
I open ecu and read eeprom 93c86 ok,
I see the tiris of 4c valet key in dump (CC 11 84 0A ), i try to add master 4c key to dump manually,
But no any respond from car when insert the new key added to dump by me,only the valet key ok work,
I try to load virgin file for camry with 93c86 (i think it is the same structure), the same no any respond while inserting the keys,
I try to add key by tango but not find alphard on tango key maker,
can any one help me to get virgin file with the same label on ecu,thanks in advance
try this
best regards
fadhle (19th September, 2017)
Try this, use original 4C kAlphard 4c key ecu 93c 86 89661-58030 Reset.zip
Many thanks friends for your helps.
sadarmeng up to now i dont get pass.
hi, I have a alphard 2004/5 ECM 89661-58031 denso 275100-0120. I need dump file for eeprom 93c86. Please help is needed AKL
hi there i got an alphard that suddenly wont start and trouble code is immobilizer fault ... could i try this immo off file?
I have two dumps from 9386 chip but not immo off. Is this what you are after.?
Hello friends, can anyone give me virgin of 93C86 for alphard 89661-58031. I am need it friends. IMG_20200801_051329.jpg
Sent from my Redmi 7 using Tapatalk
can i get password for this file....need to reset immo
