norishor (29th December, 2017)
Hello everyone PSA Chinese key need to hitag2 prepare for remote function?
I have pcf7941 and pcf7961 "ASK", all starts 55 in the line RSK lo line, the rest of the code is interesting for a specific car YES OR NO
First 6€ key 55A2..... successfully program on 307 CAN remote OK
& 13€ KEY 5559.... successfully program on C4 2005 remote OK + light
i suppose all Chinese key PCF7941/61 are operational , same CODE in user P1 and Remote RSK lo
Last edited by TERMINATOR1000; 20th September, 2017 at 03:55 PM. Reason: after test on car !!!!
7941 is CE0536 ASK, config use up to 04/2011
7961 CE0536 after 2011????
Hello , after 2009 for Peugeot and 2011 for Citroen it's just FSK frequency signal type who change .
I hope somebody can explain me the process of synchronizing to Remote control fonction and immobilizer fonction .
if you can use PCF 7936 with another with another Pcf7961 Chinese key ( without coil ) just for open the door , because $6 key are very poor quality and fiability
SYNCHRONIZATION procedure i need , what HITAG2 USER informations in PCF7936 is necessary for what HITAG2 REMOTE informations in PCF7961/41 ?
BR
Can you confirm this info ????
Old Kline pcf7961 ASK *fixed key Chine ( Orig Key 7936+remote) -2005
-folding key
0523 Kline Pcf7941 (-2005) ASK/FSK (Vans -2007) (passenger cars -2005)
0536 Can-bus (+2005) Pf7961 ASk/ FSK (FSK 2011+) *
*the order of 7961 and 41 is not clear right now
excuse my English, is the best.
TERMINATOR1000 (19th September, 2017)
"what HITAG2 USER informations in PCF7936 is necessary for what HITAG2 REMOTE informations in PCF7961/41"
You need USER page beginning with 55. Other 3 bytes are the remote code. Also you need to know exact type of remote for your car. It is on USER2 page and canbe 0A55FFFF, 0C7AFFFF for example. This indicates the model of car. In these examples they are for 307 and 206 respectively.
kleidaras (20th September, 2017), TERMINATOR1000 (19th September, 2017), YOUNESTA (10th May, 2018)
Thanks my friends
It's very complicated ! lot of model of car with only 4 type of key , locksmith is à real job
I need Citroen C4 HITAG 2 pré-code , but i just have genuine standard pcf7936 key , can i retrieve this info with cn900 mini in this key ?
Or somebody can show me this Hitag 2 pre-code ( for 0523 Kline pcf7941 )
Best regard
As I post on other threads if you know pin code of the car that PCF7936 belongs I can give you the ISK to read it.
Cesarec (22nd September, 2017), Locksmith Hungary (21st September, 2017), morfej (16th February, 2018), RIMKACHIP (6th November, 2017), TERMINATOR1000 (20th September, 2017)
Your ISK is 1E650B74BCAF. Known ISK can give many PIN's because of algorithm entropy. If you're lucky they can be only 3 but case with 22 is also possible.
Cesarec (22nd September, 2017), lidons (22nd September, 2017), Locksmith Hungary (21st September, 2017), morfej (16th February, 2018), qwertyuiop12 (22nd September, 2017), TERMINATOR1000 (20th September, 2017)
you are serious ? GIVE ME YOUR SECRET TOOL !
bearheroes (13th October, 2017)
Hi RFRemotes, maybe can you build table with all PSA ISK. I will try write script for RWprog for find ISK in PSA key. Or maybe can you send me algo PIN to ISK?
http://bicotech.com/?page=prod_rwprog&lg=en
Hello
For Peugeot Partner 2 ( after 2009 ) this seller :
https://www.aliexpress.com/item/CE05...311.0.0.X7O1NM
Chose Frequency FSK
Size:3BT CE0536 VA2T
fast shipping top quality , low price : THE BEST !
castin (17th February, 2018)
