Results 1 to 8 of 8
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    Default 2012 vw polo vivo 1.4 trendline remote key
    would X-100 pro be able to program a vw polo vivo key ID 48 IJ0 959 753 AH 433Mhz i have transponder key only remote key were lost need to add this key to the system any advice would be appreciated
    'If I helped, please click Thanks +Reputation.. !'
    Apr 2016
    uk
    Quote Originally Posted by rtbdiagnostic View Post
    No..
    I don't think so.
    You need proper tools like vvdi2 supervag ..the remote code should end with 753da
    Inviato dal mio HTC One utilizzando Tapatalk
    Jun 2013
    This is South Africa model?
    In Europe this model was delivered from 2002-2009.
    So yes you, you can solve this with various solutions and tools.
    I am sure you know, that you can get the remote to work even without OBD.
    And choose a way to solve the ID48. There is many options. EEPROM is crypto.
    You find all you need, here at DK.
  4. The Following User Says Thank You to Weasel3 For This Useful Post:
    rtbdiagnostic (20th September, 2017)
    westville locksmiths's Avatar
    Sep 2011
    South Africa.
    hi, the 753 AH will also work, manual coding for the remote or by mvp pro. transponder can be codes with avdi, super vag or vcds.
  6. The Following User Says Thank You to westville locksmiths For This Useful Post:
    rtbdiagnostic (28th September, 2017)
    May 2015
    My Tool Room
    any instructions on how to programme these remote manually
  8. #6
    May 2015
    My Tool Room
    hope this is correct procedure - key that works ignition on - key that does not work in drivers door lock - press unlock button once - lock the door then unlock the door - take key out - switch ignition of and take key out - the key should be programmed ....
    Manual Programming
    1) Unlock the door to your car using the key blade
    2) Insert your old key blade into the ignition and turn it to the "on" position, but do not start the car.3) Roll down your driver's side window
    4) Step out of the car and insert your new key into the driver's door lock, now turn the key to the left and hold it in that position for 10 seconds.
    5) Now press the lock button on the FOB
    6) Now press the unlock button on the FOB
    The car should blink its flashers or beep, letting you know that programming is now complete
  9. #7
    May 2015
    My Tool Room
    would the ck 100 or sbb v46.02 also work on these megamos crypto id48 transponders...
    Quote Originally Posted by westville locksmiths View Post
  10. #8
    wissamshaat's Avatar
    Oct 2017
    france
    keydiy work and you can use it later for other car
    you bring keydiy remote and add a blade and the transponder in the normal key
    and you have a working remote key
