Results 1 to 12 of 12
    Apr 2011
    Default Help with tacho nec78 and dgp3
    hi , i try recalibrate dash in Peugeot 307 years 2003 with DGP3 and adapter st59 but always give me this error ..... PINCHECK
    i use this pinout
    pin 2 y 11 need lift of Pcb and solder The wiring or Only solder in The pin ???
    Apr 2011
    someone that make this with dgp3 clone ??
    brend's Avatar
    Oct 2015
    Same where
    Yes 2-11 pin must lift.
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    That pinout is not correct
    Sep 2013
    use this pinout:
    Good Luck!
    Apr 2011
    but this pinout is for dgp3 ?? or any nec programmer ??? with this pinout need lift pins ???
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by m35i View Post
    You tried read lift pin ???
    Apr 2011
    yes i try but not read with pinout of dgp3
    Cllau's Avatar
    Mar 2017
    where friends need me
    Dgp3 Clone it `s not good on nec...
    brend's Avatar
    Oct 2015
    Same where
    jomberykaso give to you good conection.My digimaster have to conection like jomberykaso sulution and my tool worked .Maybe your adapter just not work.
  11. The Following User Says Thank You to brend For This Useful Post:
    jomberykaso (21st September, 2017)
  12. #11
    Sep 2013
    for any nec programmer
  13. #12
    Apr 2011
    not work i think that this adapter is very bad for this work
