It should be simple...
Bought used BSI, virgin 95128 then connect to the car
but engine didn't start... Any ideas how to code it?
try this
VIN : VF7LC9HXC74518428
PIN : TW88
your virgin BSI ;
Hitec2rcd (21st September, 2017)
Thanks! Tested same File before, but nothing... Is IT possible to just put virginized BSI into car and start engine? Or program with lexia clone, but no idea how.
.....tr this
Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
HI WHENE YOU PUT THE VIRGIN BSI TO THE CAR IT WILL NOT START YOU NEED TO REPROGRAM THE KEYS TO THE BSI AND THE CAR CONFIGRATION
GOOD LUCK
Do I need a brand new transponder, or could be old keys? Always result programing is non response from bsi.
tr new pcf7936 recode all with psa
Hitec2rcd (1st October, 2017)
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
