Page 6 of 7 FirstFirst 1234567 LastLast
Results 76 to 90 of 92
  1. #76
    Meat-Head's Avatar
    Quote Originally Posted by noppathon View Post
    can not read opel zafiara 2.2 year 2002.can help me.
    Wrong car for a start, if immo2 nil poi
  2. The Following User Says Thank You to Meat-Head For This Useful Post:
    noppathon (7th June, 2014)
  3. #77
    Aug 2012
    holaaaaaa hay alguien de madrid
  4. #78
    Aug 2012
    nadieeeeeeeeeeeeeeeeeeeeee
  5. #79
    Oct 2015
    Quote Originally Posted by Galee View Post
    Don't know if I have the same issue I have a vag tacho 2.5 cable but had to reformat my hard drive and can not find the cd that came with it.
    I have not used any newer version software with it. So downloaded the 2.5 software pluged the usb cable in. The computer reconised it when pluged in but when I open vag tacho 2.5 it says interface not found please see attached software and mprog dump.
    Will I need to reflash the cable or do I have the wrong drivers?
    excatly the same problem, anyone has a solution?
  6. #80
    Nov 2015
    I've got another problem. I've tried any versions od vag tacho dumps on my china vag tacho 3.01, and I have always, that Usb to K-line interface is connected ID:xxxxx, but when click on Connect Selected ECU got:
    Warning: No 12 volts power supply from OBD connector!
    Warning: K-Line Fault - Short circuit to Ground!
    I even change the L9637D in interface, but still got no connection. Maybe anyone got the cd to this china cable ?
  7. #81
    dadal's Avatar
    Aug 2015
    Quote Originally Posted by datapage View Post
    Use mprog 2.8
    Program with file VagTahoUsb22.ept
    Then run VTU-2XX-UA.exe
    Removing and Replacing the usb.
    Ready.
    Perfect
    Hi mate thanks works perfect
  8. #82
    Oct 2016
    How do you flash cable? is there any instruction on that?
  9. #83
    Portugal
    Hello. I have some doubts and I wish they could clarify and help at the same time. I have vag-tacho2.2 and can I use a version above?
    I have a cable vag can comander 5.1 never got it by running, can you give it back?
    thank you
  10. #84
    Sep 2018
    Earth
    Little old topic but safe my cable. So, here is what happen. I also bought from Ebay clone that claim to be 3.01. One time it start (to test it) and then it went dead..
    I try to fix the FTD serial, but the software despite starting began to complain that "12V not present..." , "K-line short to the ground.." or similar..
    Well, no connection to any VW - AUDI dash.. Damn.
    Then I found that topic and in post #68 was some RAR pack that content FTD file, DATA and EEPROM memory HEX files.. And it bring it back to life...
    What where my steps :
    1 - open the cable, and found out that the green cable (data line) get broken right away.. So, I cut and re solder all of them
    2 - cut that line. Have no clue why pin 7 (K-line ) is connected to pin 3 (non universal) but for my range of use do not think will do something good to have K-line tight together with pin 3
    3 - move the Atmel to programmer
    That one is cheap , but work great..
    As the Atmel was removed, I reflash the FTD chip
    4 - select the Ft245RL.ept file using attached MProg
    select "EDIT" , and wrote the serial number, then using the blue flash logo , flash the cable. Then press READ to confirm I get the number inside:
  11. The Following 3 Users Say Thank You to longgo For This Useful Post:
    bendzji (1st January, 2020), oxwilliox (16th May, 2021), pjakub (13th December, 2022)
  12. #85
    Sep 2018
    Earth
    Because only 5 picture per answer, will write second post.. sorry
    Next wrote data in the Atmel chip.
    - select right chip info:
    - leave the fuses as is , and all data to be FF FF filled and push write. That manage to erase the chip
    - next select the proper files, and select the right destination:
    - set the FUSES and burn.
    Solder the chip on place and that 12V and K-line errors disappear, and the cable with 2.6 software flawlessly manage to read the pin code from TT N8 dash..
    Thanks folks for the great forum and files!
    p.s: bought 2 new ATMega 8A chips but manage to use that one what come with the cable. Anyway, perhaps better just to replace it with new and flash the software..
    Last edited by longgo; 11th February, 2019 at 06:41 PM. Reason: forgot to mention..
  13. The Following 5 Users Say Thank You to longgo For This Useful Post:
    bendzji (1st January, 2020), mexanico1971 (16th April, 2024), oxwilliox (16th May, 2021), pjakub (12th December, 2022), root toor (3rd November, 2020)
  14. #86
    Apr 2019
    ive tried quite few times. but un successful.
    Many years ago I was using cable ( china vagtacho 3.01 from eBay.co.uk ) and I had a problem with it. I remember that I was messing about with it with mprog and somehow I have fixed it.
    Now afer few years I wanted to read PIN from different car and cable is death again.
    It might be the fact that I dont have winXP , but win10 x64.
    however Ive tried even running XP in virtualbox. still no success.
    then Ive found this site and i can hardly remember that I was "fixing" cable somehow like this in the past. ( with mprog ).
    I highly appreciate any help that anyone provides. However I guess that there is plenty users like myself that don't know what to do at all and might need a bit more help with that,.
    So can someone please sum up what the steps are to make that cable run again?
    I'm pretty sure that last time when i did it ive only did something in mprog program and then problably had it running fine./..
    some users writes there about some fuses etc... ? wt?? what fuses ? there is no such option in mprog at all or do i missing something?
    I have windows 10 x64 and Vag Tacho cable 3.01
    how can these two working together?
    If it's necessary i can run it under windows xp in virtual box, but i prefer not to.
    thank you very much for any help of info that will make it run again.
  15. #87
    Nov 2019
    Россия
    all the best! Does anyone have a cord dump of vag tahoe 5.0?
  16. #88
    Mar 2016
    Portugal
    Thumbs up VagTacho 3.01
    I know this thread is old, but I would just like to thank those people on here who took the time to upload fixes, I've finally managed to get my
    VagTacho 3.01 cable working after owning it for 3 years. I don't know which fix brought it back to life and I have no intention of playing with the
    cable to find out, it now works as it should, so thank you !
  17. #89
    Jan 2022
    Can i replace 93c46 with 93s46 in vag tacho ft245bm, change PID to D99 and serial with mprog and use atmega firmware from version ft245rl vagtacho 3.01?
    What i don't understand is that on the schematic of vagtacho 1.0-1.7 on eeprom 93c46 pin 7 DC is pulled low and pin 6 ORG is pulled high.
    On 93s47 pin 6 W would be pulled high all the time. Would it work?
    Can v1 work up to v3 with 93s46?
    Can someone post schematic of vagtacho 2.5 - 3.3?
    I am writing about this post:
    https://www.digital-kaos.co.uk/forum...l=1#post348698
  18. #90
    Aug 2018
    Buenos Aires - Argentina
    Quote Originally Posted by longgo View Post
    Thanks a lot! I just did the procedure as described and revived my VAG TACHO 3.01!!!
    Excellent Tutorial!
