deutschmann (14th March, 2016)
Your dump from atmega is useless !
Do you look at this dump after you extracted?
If not, take a look now
P.S. The atmega uC in general has security bits fused... so it is a little bit hard to extract info from them...
Regards!
Last edited by alin 151; 30th June, 2013 at 05:47 PM. Reason: Added eeprom and flash hex
@alin 151
Man, as I told you before, your dump is not good!
Don`t post`it anymore!
Dautra (16th November, 2019)
After long searching and testing, this is the kit for VagTacho 3.01 FT245RL
1. Write ATMEGA8 with the vagt2.6Flash and vagt2.6eeprom files
2. Set Fuses
3. With Mprog rewrite FT245RL
4. Install the drivers
5. Run VTacho serum-CD715B710A.exe
Works with vagtacho 3.01 and all previous versions!!!
Good luck everyone!
Don`t forget to THANKS!
Last edited by alin 151; 27th September, 2012 at 06:43 AM. Reason: Moved to new post
alyvo (5th February, 2017), bendzji (1st January, 2020), CasaEd (11th January, 2021), dbladde (18th February, 2019), electronistul21 (11th October, 2017), Eugenics (15th June, 2021), ghicicine (1st August, 2015), ikea (3rd November, 2018), intrade (23rd May, 2018), koko954 (2nd June, 2021), longgo (11th February, 2019), mexanico1971 (13th April, 2024), mikilovitch (1st May, 2014), NORSHAN (13th August, 2013), nth2 (11th October, 2015), n_roy (13th October, 2020), opel17 (23rd December, 2015), oxwilliox (16th May, 2021), pjakub (8th April, 2020), quattro-rs (21st September, 2014), radioman (16th October, 2013), root toor (3rd November, 2020), semga (9th October, 2015), skona (31st July, 2014), srzar (20th March, 2023)
Don't know if I have the same issue I have a vag tacho 2.5 cable but had to reformat my hard drive and can not find the cd that came with it.
I have not used any newer version software with it. So downloaded the 2.5 software pluged the usb cable in. The computer reconised it when pluged in but when I open vag tacho 2.5 it says interface not found please see attached software and mprog dump.
Will I need to reflash the cable or do I have the wrong drivers?
opel17 (23rd December, 2015), zigzag2588 (12th September, 2017)
Is the cable hw compatible with VCDS and vice versa? I have an VCDS clone 10.6 cable that was disabled via original update, I cannot downgrade it because of bad H/W revision (FT232RL, GAL). Is it possible to reprogramm ATMEGA with this dump, so i coul use it with Vag Tacho?
look for *.inf files in installation folder and insert HW_ID and SW_ID pids from the control panels usb device properties
Hello
my Vag tacho 3.01 had a problem can not read opel zafiara 2.2 year 2002.can help me.
