Thank you. Solved with a file from DK.
Only U1600.
Hi mates, I have here a Fiat Ducato 2.0 JTD with a problem with immo. I want to remove IMMO with a tested solution and without fault code U1600.
Attached is the original 29F400BT read with FGTech II. Can someone remove the IMMO and the U1600 fault code.
Thanks in advance...
2004 Fiat Ducato 2.0 JTD
Bosch ECU 0281010346 / 9646138580
SW: 1037369277
Only U1600.
Kprog (22nd September, 2017)
please send file solution. same problem !!
This is the file, but it has U1600.
illestibor (5th March, 2021), Kprog (25th September, 2017)
try this
here without U1600
Rocko.
in car starts, but the fault still comes out, when you accelerate the fault comes back.
Thank you for the mod file rocko,
I cant read ori with mpps and kess v2, strange no ? ( I can read only ID with mpps )
مرحبًا ، لا يوجد IMMO OFF
if only flash flash and eeprom not. after the throttle is added, the engine error and the error code with rail pressure light up. eeprom also needs to be adjusted, line 180: 00 00 ......
