Now is time to fill those pipes with the right amount of refrigerant ,i bet there is none left.
I have a Kangoo 1.9D 2006 with a problem with the air conditioner. With the engine on, the blower blows air, but the compressor clutch doesn't engage.
I tried activating the compressor clutch relay with a delphi ds150e, it works fine and i can see the clutch engaging. With ignition on, I move the AC knob (not the blower) to activate it and I hear a relay below the glovebox working.
But with engine on, the compressor clutch is not engaging, I can't hear the relay below the glovebox because the engine is loud as shit. Blower works fine. Fuses are all ok.
What could be the issue that cause the clutch to not engage with the engine on?
A failure will not appear till a unit has passed final inspection
Meat-Head (24th September, 2017), nenadgorgi (23rd September, 2017)
Forgot to mention. I pushed the filling port valve with a screwdriver, gas came out with tons of pressure so it seems it's quite full. Will try to get the pressure measured, but I don't think that's the problem. I didn't have much time to check on the car, but I think the relay below the glovebox is the issue, were checking all the cables, and there's one that is the same color as the one in the compressor, and it never has voltage. Will try to check it tomorrow.
Meat-Head (24th September, 2017), nenadgorgi (24th September, 2017), wokcz (25th September, 2017)
More likely to be either lack of gas but more likly the trianary switch
Unlikely but small chance dK thanks button not pressed enough could cause it
