You need comvert your bin file to hex format, not just change file extension.
Then flashmagic will allow you to burn it into lpc chip.
please i need the boot file to reflash my pcb v4-1
bcoz my my device is dead. giving me this msg
the device has been deactivated.
i found her firmware LPC1788.bin but when i reflash it using flash magic
using .hex extension it give me this message
Flash Magic
The hex file is invalid. Please select a valid hex file and try again.
when i use .bin extension it give me this message
Flash Magic
Operation Failed. Nothing to program. Is the hex file inside the device memory range?
can anyone help me with right steps&boot file or dump to solve my device please.
any kind of help will be appreciated.
B.RGDS
Islam
hello Mr. morgano
thanks alot for your interesting and reply
i did comverted to hex and burn it successfully. but the firmware is not compatible with my device.
so i need fw generator to creat my fw&db files.and i looked up for fw generator everywhere but nobody wanna help.
i found one here but missing see attached.
if any one can send me the fw generator.i will be really appreciated.
once again thank you so much for your interesting.
B.RGDS
Plah (21st January, 2018)
Need help. My FVDI died. Help to restore.
Help make file. My id chip ; 0C8000136218C5AE99C47756C31C00F5 Serial number F01376.
I have the same problem and nobody can help find the hex file. Please tell me what you did with it. Have you found this filehttp://cloud.tapatalk.com/s/5fd06e34...129-WA0009.mp4
تم الإرسال من Redmi Note 6 Pro باستخدام Tapatalk
voila fls pour npx fvdi 2018
1981Andrii (30th March, 2023), Brown012 (11th March, 2022), Col19 (6th June, 2021), makadam (28th December, 2022), MARTINHDX (26th December, 2021), oldero (15th February, 2022), popescuvali (29th April, 2023), Romanki (21st May, 2022)
May I please connection diagram to mainboard?
If my solution helped You - do not forget to THANKS !!!
