    gomarota's Avatar
    Default BIG PROBLEM DRIVING ME MAD, RENAULT/NISSAN EDC16C3-10.22 P0606
    Nissan primera 1.9 renault engine
    Hi i explain very fast the problem
    ecu is 0281011646
    P0606 computer
    when driving car shut off
    i changed ecu for other compatible
    i changed bdm files (mpc,flash,e2p) from carlabimmo and put virgin eeprom, i code injectors and same problem
    Anyone can help me with this? i dont know what to do more
    LOVE DK!
    Jun 2013
    EU
    No DTCs present when car dies?
    Once running and passed immo stage not many things can make car shut off.
    Not enough fuel arriving to the engine, implausible signals from a critical sensor (crackshaft,...) or electrical problem feeding the ecu (having swapped the ecu discards ecu itself).
    Good luck
  3. The Following 2 Users Say Thank You to morgano For This Useful Post:
    dijo (24th September, 2017), gomarota (22nd September, 2017)
    gomarota's Avatar
    yes when car dies 1 dtc: p0606 computer
    thats the problem i dont have any more dtc regarding sensor or feeding voltage dtc, ecu is edc16 should be more helpfull
    after power off i can power on instantly without having to wait some time
    soooooooooooooo strange
    LOVE DK!
    Jan 2016
    Try unplugging egr valve, does same thing happen?
  6. The Following User Says Thank You to Cr4nky For This Useful Post:
    gomarota's Avatar
    will try now
    LOVE DK!
  8. #6
    gomarota's Avatar
    Solved, check the wiring loom, oil inside and made short circuit
    thanks friends
    LOVE DK!
  9. The Following 3 Users Say Thank You to gomarota For This Useful Post:
    dijo (24th September, 2017), giani67 (5th December, 2020), rytismulti (15th August, 2018)
