Results 1 to 13 of 13
    Feb 2010
    Bosna
    Default Berlingo SID801A egr and error codes P0402 off
    Somebody pls help to remove egr and DTC P0402 from this old sh.t.
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Try and report . Dont forget to press thanks and reputation button
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
  3. The Following User Says Thank You to Ignasvw For This Useful Post:
    mvekaz (22nd September, 2017)
    morfej's Avatar
    Dec 2008
    Just delete the P0404 as well and you can disconnect the EGR (blue plug and hose).
  5. The Following User Says Thank You to morfej For This Useful Post:
  6. #4
    johak's Avatar
    Apr 2010
    try and report
  7. #5
    Feb 2010
    Bosna
    Ok someboda pls remove p0404.
  8. #6
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    EGR faults off. press reputation button (star)
  9. #7
    johak's Avatar
    Apr 2010
    Quote Originally Posted by Ignasvw View Post
    the file is 16bit LOHI not HILO
    looks like you've seen it wrong
  10. #8
    johak's Avatar
    Apr 2010
    Quote Originally Posted by mvekaz View Post
    try my solution
    in this file I did not see dtc p0404
    or unplug egr and post dtc here
  11. The Following User Says Thank You to johak For This Useful Post:
  12. #9
    Feb 2010
    Bosna
    You are in right, scan with diag, there are two DTC P0400 and p0402, there is no P0404 DTC.
    Ok, what is password for rar?
  13. #10
    johak's Avatar
    Apr 2010
    I sent password PM
  14. #11
    Nov 2016
    İST
  15. #12
    Nov 2016
    İST
    Default Berlingo SID801A egr ve hata kodları P0402 kapalı please sör.
  16. #13
    Mar 2016
    Can help somebody with same situation - EGR OFF - P0400, P0402 - KTAG - read/write ?
    Thanks !
