Results 1 to 9 of 9
    Jan 2017
    Default honda crv 2016 clear crash
    Hello, i need to clear crash in honda crv 2016
    77960-t0a-a212-m1
    95640 eeprom
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Your cleared tested file, pass in pm.
    Best regards.
    Dragon
    Jan 2017
    I have dtc B0090-87 and B0095-87 front impact sensors.. are their broken or crash is not cleared? wiring from sensors to module is ok
    dragon100's Avatar
    Jan 2012
    I think so sensors are broken ...
    Best regards.
    Dragon
  5. The Following User Says Thank You to dragon100 For This Useful Post:
    repairmymodule (23rd September, 2017)
    repairmymodule's Avatar
    Aug 2014
    USA, Earth, Milky Way Galaxy, Universe, Unknown
    You can always check crash with scan tool. Read Data stream, select all Front and Side Impact PIDs, if all display OFF then no crash.
  7. The Following User Says Thank You to repairmymodule For This Useful Post:
    dragon100 (23rd September, 2017)
  8. #6
    Jan 2017
    impact sensors are ok. I checked in another honda. I attach screens of data stream and dtc.IMG_0832.JPGIMG_0833.JPG
  9. The Following User Says Thank You to srck For This Useful Post:
    repairmymodule (24th September, 2017)
  10. #7
    dragon100's Avatar
    Jan 2012
    Check this, if not work, you need use diviner ...
    Best regards.
    Dragon
  11. #8
    Oct 2015
    may be impact sensor ...use vin number check impact sensor is correct or no....normally clear crash file,no have code impact sensor...if part number correct need try check wiring impact sensor ,try ur best
  12. #9
    Jan 2017
    Can someone help me with check correct number of front impact sensors? Now i have 77930-t1g-a010-M4.. car is after crash and i think that somebody repaired and install wrong impact sensors.. i was changing sensors to the same number and i still get dtc. Sides impacts have 'M1' tag.
    vin number: 2HKRM4H35GH663840
