Wrong 4Pg.
Try 4B 48 49 43 50
Master key on 2pg have 0A slave 05
Hello
I have Kawasaki Z1000 2005 year with Denso ECU 21175-0097 with lost all keys. I have try with Tango to program keys but it doesnt work,I try first with CN2 Transponder and then with TPX2 Transponder, both transponder I program on key number 1(master?).
So could you help me about that ?
Thank you...
Bruno
Wrong 4Pg.
Try 4B 48 49 43 50
Mezz_cro (25th September, 2017)
choise kawasaki denso 21175-0220 or kawasaki denso 21175-0356. should be good.
6841707059 576F526B 57416E5453 596F55 526F6B69424152
alclot (25th September, 2017)
Erase that eeprom couple of times before writing new file back. I had same problem on that same bike before
Mezz_cro (26th September, 2017)
I have try everything and dont work... Some other idea?
what eeprom programmer are you using to erase it.
it is for sure the atmel eeprom.
for example i erase chip with tl866 about 10 to 15 times then write file back then it takes.
you can code 4d60 chip cn2/5 tpx etc key will be written in but for some reason those atmel eeps are stubborn..
Mezz_cro (28th September, 2017)
and code it at key-2 position
I have tryed with UPA and ORANGE to erase eeprom (yes ATMEL), and program 4d60 with TANGO...
I can try on key-2 position, that is my last hope...
I programed new eeprom and add key on position 2 and kawasaki starts! Thanks everybody on help
What do you mean new eeprom?
Tango dont need write dumps back to eeprom
