Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
Thread: Bmw 520 2007!
  1. #16
    nickolasd's Avatar
    Nov 2015
    find a flash out of cas with exactly the same part number and write it to your cas, use your original eeprom.
  2. #17
    levisdj's Avatar
    EcuLand
    Mine's : 61.35-6943834-01 2070762416 MCV:00.00.00 FSV: 1.7.5 OSV 3.3.0 HW C4 SW 12.5 COD 08 Diag index 06A6
    SOLVED... so there was nothing wrong with the CAS unit it was the ribbon plug going inside the CAS it didn't make contact properly!!! So for those who seek a good flash and eep with this numbers, feel free to use it because it's good! Thanks all who answered!
  3. #18
    Flash (61.35-9217853-01) is correct.
    Check soldering.
    WBR, Marek
  4. #19
    Jun 2017
    BALKAN
    take another cas. write youre eprom in. then you will have ignition. then synhron cas dme and start car
    BMW FOREVER
  5. #20
    levisdj's Avatar
    EcuLand
    As double post : SOLVED... so there was nothing wrong with the CAS unit it was the ribbon plug going inside the CAS it didn't make contact properly!!! So for those who seek a good flash and eep with this numbers, feel free to use it because it's good! Thanks all who answered!
  6. #21
    levisdj's Avatar
    EcuLand
    Reopening this thread...customer called and said that the yellow cut key comes up while driving... if he stops the car, locks and unlocks it restarts...!I'm getting the car back tomorrow morning to get diagnostics onto it.... will update soon, meanwhile if some of the other users experienced something similar, please feel free to share a sollution.Thank you
  7. #22
    BMW CASS ARE VERY HARD.
    IF YOU LEAVE THE KEY ON SCREEN, YOU MUST SYNCHRONIZE CASS
  8. #23
    levisdj's Avatar
    EcuLand
    So it can't be that the CAS is defective ? I can't seem to get to the point in where's the problem ... all errors seem to be random.Not something to point onto...!!
  9. #24
    let customer use second key and see if problem still there.
  10. #25
    levisdj's Avatar
    EcuLand
    Same for both keys vageric ...
  11. #26
    then i think your cas is defect.
    hardware or software
    try first useing a other flash to see what will happen.
  12. #27
    levisdj's Avatar
    EcuLand
    updating from diagnosis : CAS errors : 9a04 9a07 9a11 9906 9909 (Under shadow menu) and regular dtc-s A0F0 CAS Transponder coil
    I had another module with an error, but I don't know if it's relevant from CAN Gateway E18F MOST ring Setpoint actual configuration does not match!
  13. #28
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by levisdj View Post
    Chek coil socket what go in cas.
