Results 1 to 15 of 28
Thread: Bmw 520 2007!
    levisdj's Avatar
    EcuLand
    Default Bmw 520 2007!
    I just got in this bmw, opened CAS... found 0L15Y mask 512... Please point me in the right way into reading this CAS unit safely, I have r270 ... Tryed with DigiMaster3 with the adapter for CAS but it says NOT found device. Thanks!
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by levisdj View Post
    If r270 blue box clon its just killer for cas.
    Digimaster 3? What adapter you use for reading?
    levisdj's Avatar
    EcuLand
    Super BDM Programmer... I also have Cas BDM ADAPTER (Not programmer) and the R270 is black box clone!
    brend's Avatar
    Oct 2015
    Same where
    Now i use anether programmer for this, befor i use digimaster 3 ,for cas 1,2,3,3+ use adapter CAS BDM ADAPTER not super cas bdm .And its working good and no problem jet.Check conection.
    brend's Avatar
    Oct 2015
    Same where
    About black R270 , people talk working safety and 5% talk its kill eeprom
    levisdj's Avatar
    EcuLand
    So I should go with the DigiMaster 100% safe, right ?
    brend's Avatar
    Oct 2015
    Same where
    My experience.. YES.... ,because i to do very much cas with digimaster 3 and before i say no problem jet.
    levisdj's Avatar
    EcuLand
    It worked for a while, after it said not find device, and now it doesn't recognize the key!.... did I messed it up ???? DAMN!
    brend's Avatar
    Oct 2015
    Same where
    I think , or R270 or SUPER CAS BDM kill eep. or mcu , very bad .Try with digimaster 3 read this or another programmer like x-prog,vvdi,orange5.
    levisdj's Avatar
    EcuLand
    With Digimaster3 I did it ....!!Now what ??
    brend's Avatar
    Oct 2015
    Same where
    Wrong adapter and maybe wrong conection mate because. Try read this another programmer,if read good send damp here and cas nr. maybe DK people help you .
    brend's Avatar
    Oct 2015
    Same where
    My digimaster never kill eny ecu if use corect adapter and conection.I working with this 2 year and no problem jet.
  13. #13
    levisdj's Avatar
    EcuLand
    I checked four times before starting, so YES the connections were OK... I'll try r270
  14. #14
    levisdj's Avatar
    EcuLand
    Here is flash and eeprom read by R270
  15. #15
    levisdj's Avatar
    EcuLand
    I get A0AA dtc, unit faulty... can someone fix my files please ?
