Results 1 to 7 of 7
    Ahmy501's Avatar
    Jun 2016
    Default Peugeot 206 1.4 Immo OfF
    I need a tested solution i have already tried several dumps found on DK ECU info is attatched HOM Sagem S2000-23 9644625680-00
    PSA 21646584-5
    IND : A
    50409805
    Burned more than 7 dumps car never started i made sure all dumps are as close to my ECU as possible also PINs F4/F3 are already gone from middle plug.
    rafal's Avatar
    UK - PL
    try and report
  3. The Following User Says Thank You to rafal For This Useful Post:
    Ahmy501 (24th September, 2017)
    Oct 2016
    Default Here you go
    I have faced poblem like yours first try to solder the pins F3 , F4 that you removed because sometimes they are connected to crankshaft sensor !
    also give a try with my file
    tell me the results after you do this
  5. The Following User Says Thank You to fady eid For This Useful Post:
  6. #4
    Ahmy501's Avatar
    Jun 2016
    @ rafal cheers for the file i`ll post results later
    @ fady eid Thank u for pointing out i`ll try with immo lines connected/disconnected.
    Ahmy501's Avatar
    Jun 2016
    Tried both dumps, job was a failure i`ll re solder the disconnected pins and try again.
  8. #6
    Oct 2016
    waiting for results hope it works for you
  9. #7
    Feb 2016
    tengo problema con la ecu sagem s2000 del motor 1.4 8v y se me apaga el tablero cunado le doy
    arranque. pruebo con este off
    gracias y depues comento
