Results 1 to 13 of 13
    dave11674's Avatar
    Florida, UK
    Default Seat leon SAFE after disconnecting dash with ign on !
    Hi guys
    wonder if anyone can shed some light on this problem i got with a seat leon 2006 1.6 petrol.
    basically i was doing a but of work on the speedo
    as i pulled it out (micronas)
    i realised the key was still in and turned !! Oooops
    so after finishing my work i refit the dash only to have SAFE where the trip is supposed to be !!
    car starts up but cuts out after a secind.
    i read immo block from dash with smok and all looks good
    so i thought id code another transponder in slot 3
    that went ok and i wrote security block +1 back to the dash but still safe !!
    in the end i did immooff in the siemens 7.1A
    but still had safe on the dash
    can anyone shed any light on this in case it ever happens again
    andhow its fixed
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    Smok PSA, volvo & ford
    If someone helps you DONT FORGET TO SAY THANKS its only polite....
    szengen's Avatar
    Jan 2017
    Give some information that you've been cherishing, and what?,No xcan vw package on your hardware?
    Jan 2013
    find good immo file from micronas dash and type your immo data (e.g. from ecu) manually then write it to dash
    i had similar case and i have done it as i described it above with abrites
    component security and some other main immo data offset moved for one or two bytes
    check it
    regards
    dave11674's Avatar
    Florida, UK
    Ahhh thank you rocko
    so if i get pin and say recode dash with vcds will this do it ?
    when i read sec block with smok xcan (yes i have packages szengen) dunno what you was getting at here with your comment !!!
    the sec block looked ok to me
    ill post a pic so you can see
    nut thanks again rocko
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    dave11674's Avatar
    Florida, UK
    On a side note does tagkey tool support loading of files for this car ?
    id like to load in the dash and ecu eeproms into this software to see the change
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    Jan 2013
    i am waiting for pictures
    send all dumps you read
  7. The Following User Says Thank You to rocko For This Useful Post:
    dave11674 (24th September, 2017)
    yugo45's Avatar
    You probably have lock time . Go with VCDS to 25-immobilizer
    Then Measuring block 003 and see is there any lock time.
    After lock time go out you should be OK.
    Or if you do not have access to VCDS , post your Immo block form SMOK here and I will unlock it .
  9. The Following User Says Thank You to yugo45 For This Useful Post:
  10. #8
    Aug 2015
    unpluging dash probably is not reason of problem, what did you do after removed it anyway and did you try back it up?
  11. The Following User Says Thank You to dtip For This Useful Post:
  12. #9
    dave11674's Avatar
    Florida, UK
    @yugo
    time lockout is not in place mate
    i checked with super vag
    @dtip
    i was wiring a light up
    done that a good few times no problems.
    @rocko
    ill post files up tomo mate
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
  13. #10
    szengen's Avatar
    Jan 2017
    the devil is in detail, calmly again, step by step, best regards
  14. #11
    dave11674's Avatar
    Florida, UK
    Its all in first post mate !!
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
  15. #12
    dave11674's Avatar
    Florida, UK
    ok guys here are the dumps and a pic of the security block read with smok
    in the pic i change a few digits of the vin n immo code
    dunno why cos the orig immo block is in the rar
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
  16. #13
    yugo45's Avatar
    Can you look Measuring block 001 and 002 to see is it key recognized ?
    It will very good if you can post screen shoot of MBV 001, 002, and 003
