Hello everyone.
There is a VW Tiguan from North America which needs to be adapted to European market:
1) change odometer readout from Miles to KM in the cluster;
2) add km/h readout in digital display to be compliant;
3) change to 24 hour clock and Fahrenheit to Celsius display (both of these are optional);
4) do rear fog light;
5) US-spec radio is having FM frequency spacing of 200 kHz instead of 50kHz in Europe (or is it 100 kHz?). Is there any way to change that?
I have started with changing the region in Instruments cluster from US to RoW (Rest of World).
However, upon cycling the ignition, I get ABS and ESP lights, as well as airbag light (if I revert the coding back to US, the faults go away).
The fault codes are these:
Address 03: ABS Brakes Labels: 5N0-614-109.clb
Control Module Part Number: 5N0 614 109 Q HW: 5N0 614 109 Q
Component and/or Version: J104 C4 450 V2B2 0006
Software Coding: 0002333
Work Shop Code: WSC 01357 011 00200
VCID: 39735C4070428D6
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 178
Mileage: 1048575 km
Time Indication: 0
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 12.00 V
Bin. Bits: 00011111
Count: 220
Hex Value: 0x0000
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 178
Mileage: 1048575 km
Time Indication: 0
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 12.00 V
Bin. Bits: 00011111
Count: 169
Hex Value: 0x0000
Address 15: Airbags Labels: 5N0-959-655.lbl
Control Module Part Number: 5N0 959 655 P HW: 5N0 959 655 P
Component and/or Version: J234__204 VW10 HI 1918
Software Coding: 0012340
Additional Info: 5N0959339B BF-Gewichtsens. 003 0001
Additional Info: Geraet 00200
VCID: 4A91138C25A416E
1 Fault Found:
03551 - Functional Restriction of Seat Occupied Recognition
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Mileage: 177586 km
Time Indication: 0
Date: 2009.14.22
Time: 20:02:22
Does ABS and Airbag need some recoding?
Could someone please assist me with that?
The full scan of the car here (ignore the fault codes everywhere, is it the first scan and they all clear up):
Chassis Type: 7N0
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 65 72 77
VIN: WVGAV7AX7BW5*****
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 06J 906 027 BE HW: 06J 907 309 A
Component: MED17.5.2 TFSI 2 01 9972
Revision: P3H06--- Serial number:
Coding: 0423010A19070160
Shop #: WSC 09636 002 1048576
VCID: 6FE7A2187E86136
2 Faults Found:
008583 - Bank 1; System too Lean at Idle
P2187 - 000 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 177572 km
Time Indication: 0
Date: 2008.14.09
Time: 06:33:50
Freeze Frame:
RPM: 709 /min
Load: 20.8 %
Speed: 0.0 km/h
Temperature: 87.0°C
Temperature: 33.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.970 V
012417 - Engine Temperature too Low
P3081 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 177516 km
Time Indication: 0
Date: 2004.14.16
Time: 20:35:03
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 49.0°C
Temperature: 18.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 11.684 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09G-927-750.lbl
Part No SW: 09G 927 750 LQ HW: 09G 927 750 LQ
Component: AQ 250 6F 1771
Revision: 00H90000 Serial number:
Coding: 0000840
Shop #: WSC 01357 011 00200
VCID: 8B1F5688EA5ECF6
No fault code found.
Part No SW: 5N0 614 109 Q HW: 5N0 614 109 Q
Component: J104 C4 450 V2B1 0006
Revision: --H28--- Serial number: 00000003550924
Coding: 0002333
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 7N0 907 426 K HW: 7N0 907 426 K
Component: AC Manuell H17 0202
Revision: 00012001
Coding: 0000001002
ASAM Dataset: EV_Climatic A01005
ROD: EV_Climatic_VW36.rod
VCID: 3C7D4554B770B8E
1 Fault Found:
13701888 - Function Restriction due to Received Malfunction Value
U1113 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 10
Reset counter: 200
Mileage: 177516 km
Date: 2068.14.16
Time: 20:35:06
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 085 Q HW: 5K0 937 085 Q
Component: BCM PQ35 B++ 111 0146
Revision: BI111001
Coding: 6D580A1B80232EC4808000859000000440015186524D89605C8000000040
VCID: 418334A0D892D56
Subsystem 1 - Part No SW: 5N1 955 119 HW: Labels: 1KX-955-119.CLB
Component: Wischer 12121 012 0203
Coding: 009795
12 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 209
Mileage: 177517 km
Time Indication: 0
Date: 2006.14.07
Time: 00:00:59
Freeze Frame:
Term 15 On
Voltage: 14.10 V
ON
ON
OFF
OFF
ON
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 214
Mileage: 177517 km
Time Indication: 0
Date: 2006.14.07
Time: 00:01:06
Freeze Frame:
Term 15 On
Voltage: 11.80 V
ON
ON
OFF
OFF
ON
01259 - Fuel Pump Relay (J17)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 156
Mileage: 109927 km
Time Indication: 0
Date: 2116.14.02
Time: 12:13:04
Freeze Frame:
Term 15 Off
Voltage: 10.20 V
OFF
ON
OFF
OFF
OFF
01493 - Bulb for Blinkers; Front Left (M5)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 212
Mileage: 177517 km
Time Indication: 0
Date: 2006.14.07
Time: 00:00:54
Freeze Frame:
Term 15 On
Voltage: 12.00 V
ON
ON
OFF
OFF
OFF
01495 - Bulb for High-Beams; Left (M30)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 209
Mileage: 177517 km
Time Indication: 0
Date: 2006.14.07
Time: 00:00:54
Freeze Frame:
Term 15 On
Voltage: 12.00 V
ON
ON
OFF
OFF
OFF
01497 - Bulb for Blinkers; Front Right (M7)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 214
Mileage: 177517 km
Time Indication: 0
Date: 2006.14.07
Time: 00:58:50
Freeze Frame:
Term 15 On
Voltage: 14.20 V
ON
ON
OFF
OFF
OFF
01499 - Bulb for High-Beams; Right (M32)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 214
Mileage: 177517 km
Time Indication: 0
Date: 2006.14.07
Time: 00:58:50
Freeze Frame:
Term 15 On
Voltage: 14.20 V
ON
ON
OFF
OFF
OFF
01598 - Drive Battery Voltage
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 6
Fault Frequency: 4
Reset counter: 200
Mileage: 177517 km
Time Indication: 0
Date: 2006.14.07
Time: 00:01:58
Freeze Frame:
Term 15 On
Voltage: 14.70 V
ON
ON
OFF
OFF
ON
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 213
Mileage: 177555 km
Time Indication: 0
Date: 2007.14.24
Time: 23:22:22
Freeze Frame:
Term 15 Off
Voltage: 11.80 V
OFF
ON
OFF
OFF
OFF
02394 - Parking Light Left Front (M1)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 212
Mileage: 177514 km
Time Indication: 0
Date: 2003.14.26
Time: 07:17:57
Freeze Frame:
Term 15 On
Voltage: 14.00 V
ON
ON
OFF
OFF
OFF
02395 - Parking Light Right Front (M3)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 209
Mileage: 177517 km
Time Indication: 0
Date: 2006.14.07
Time: 00:58:51
Freeze Frame:
Term 15 On
Voltage: 14.15 V
ON
ON
OFF
OFF
OFF
02198 - Bulb for Tail Light 2; Left (M49)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 214
Mileage: 177555 km
Time Indication: 0
Date: 2007.14.28
Time: 00:46:28
Freeze Frame:
Term 15 On
Voltage: 13.95 V
ON
ON
OFF
OFF
OFF
Part No SW: 5N0 959 655 P HW: 5N0 959 655 P
Component: J234__204 VW10 HI 1918
Revision: 22014000 Serial number: 003GJPQDEXEY
Coding: 0012340
Part No: 5N0 959 339 B
Component: BF-Gewichtsens. 003 0001
1 Fault Found:
000 - - - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 2
Fault Frequency: 22
Mileage: 109865 km
Time Indication: 0
Date: 2116.14.01
Time: 13:17:47
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 501 AP HW: 5K0 953 569 F
Component: LENKS.MODUL 009 0136
Revision: FF010039 Serial number: 20101215300697
Coding: 1980140000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS_VW36.rod
VCID: 78F59944C3C854E
1 Fault Found:
114178 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 200
Mileage: 177517 km
Date: 2070.14.07
Time: 00:11:53
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5N0 920 962 HW: 5N0 920 962
Component: KOMBI H03 0405
Serial number: 00000000000000
Coding: 210700
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
VCID: EFE722183686936
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 091210F1002169
Coding: 356002
VCID: 3065616463384CE
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0405
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
VCID: EAD1330C0D6476E
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5N0 959 701 D HW: 5N0 959 701 D
Component: Tuer-SG 009 2112
Coding: 0001205
VCID: 3669577C415C62E
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 L HW: 5N1 909 148 G
Component: J500__APA-BS KL.284 0802
Revision: 1AH03831 Serial number: 00103360351101
Coding: 0000258
Shop #: WSC 00000 028 00001
VCID: 3B7F46487A7EBF6
3 Faults Found:
01288 - Terminal 30; Steering Assist
Freeze Frame:
Fault Priority: 9
Fault Frequency: 5
Reset counter: 214
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Term 15 On
RPM: 0 /min
Speed: 0.0 km/h
(no units): 2.0
Voltage: 9.10 V
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 200
Mileage: 177517 km
Time Indication: 0
Date: 2006.14.07
Time: 00:11:49
Freeze Frame:
Voltage: 3.90 V
Voltage: 7.90 V
Voltage: 7.90 V
Not Occup.
Not Occup.
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 200
Mileage: 177517 km
Time Indication: 0
Date: 2006.14.07
Time: 00:11:49
Freeze Frame:
Voltage: 3.50 V
Voltage: 7.30 V
Voltage: 7.30 V
Not Occup.
Not Occup.
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 5N0 959 702 D HW: 5N0 959 702 D
Component: Tuer-SG 009 2111
Coding: 0001204
VCID: 37775A7846569B6
1 Fault Found:
00944 - Heated Exterior Mirror; Passenger Side (Z5)
012 - Electrical Fault in Circuit - Intermittent
Address 53: Parking Brake Labels: 3AA-907-801.clb
Part No SW: 3AA 907 801 E HW: 3AA 907 801 E
Component: J540 EPB4 VW-55183 0007
Revision: H18 Serial number: 00000000082493
Coding: 0023057
VCID: 336F6E68522E776
Address 56: Radio (J503) Labels: None
Part No SW: 5N0 035 164 A HW: 5N0 035 164 A
Component: LOW NAR Tig H14 0043
Revision: -----06S Serial number: VWZ4Z6K3061459
Coding: 0500040004
VCID: 27578A3856F60B6
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5N0 959 703 E HW: 5N0 959 703 E
Component: Tuer-SG 007 2102
Coding: 0001168
Shop #: WSC 01357 011 1012552
Address 65: Tire Pressure (J502) Labels: 1K0-937-08x-65.clb
Component: RDK 111 0821
Coding: 018705
2 Faults Found:
02904 - Hard Warning 3
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 2
Mileage: 130624 km
Time Indication: 0
Date: 2121.14.06
Time: 17:00:16
Freeze Frame:
Text: 3455098620
Pressure: 1.90 bar
Pressure: 2.40 bar
Temperature: 0.0°C
Text: 00
Speed: 40.0 km/h
02801 - Hard Warning
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Mileage: 154030 km
Time Indication: 0
Date: 2127.14.03
Time: 00:23:19
Freeze Frame:
Text: 3455098621
Pressure: 0.10 bar
Pressure: 2.40 bar
Temperature: 24.0°C
Text: E0
Speed: 62.0 km/h
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5N0 959 704 E HW: 5N0 959 704 E
Coding: 0001168
VCID: 3A71434C754486E
1 Fault Found:
00931 - Locking Module for Central Locking; Rear Right (F223)
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007669043473
Coding: 0A00000000010100
ASAM Dataset: UHVNA A01007
ROD: UHVNA_VW36.rod
VCID: 32616B6C65347EE
2 Faults Found:
13635840 - Supply voltage
U1011 00 [000] - Voltage too Low
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000000
Fault Priority: 4
Fault Frequency: 0
Reset counter: 0
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
13893632 - Function Restricted due to Insufficient Voltage
U1400 00 [000] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 0
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
End ---------------------------------------------------------------------
Any assistance appreciated!
