Hello
That manual solution is 100% ok but You are change to much( Info on priv)
Luca
Hi friends,
Usually I'm helping on this forum, but this time I need some help, as I'm rather experienced in chiptuning, not in off solutions. I will be doing DPF off in my friend's focus 1.6 tdci 109 2005 and I'm wondering if solution, which relay on making zero instead of 1 in three bits is good and works well ? I'm saying about this solution :
00,7F,00,01,00,00,00,00,00,00,00,01,01,00
change to:
00,7F,00,00,00,00,00,00,00,00,00,00,00
Should I also reset DPF parameters using tester when it will be deactivated in dump ?
Opinion from experienced tuners will be very helpful.
Hello
Luca
PLEASE PUSH THE BUTTON THANKS IF MY WORK HAS HELPFULL
AND REPUTATION BUTTON (starr)
fzhut (24th September, 2017)
Yes you change to much, anyway should work
Wysłane z iPhone za pomocą Tapatalk
DSG TUNING
File Service
fzhut (5th October, 2017)
I need to disconnect anything ?
