Results 1 to 3 of 3
    Mar 2017
    Default MCZ33290 substitution
    Does anyone knows a direct equivalent for the MCZ33290 ic?
    Im reworking a carprog + adapters. All hw tests pass ok now, but I still can't get it to work with a jaeger dash, so I wanted to try replacing the MCZ33290 on the D1 adapter.
    I have to buy it at mouser (because I already have a big order almost ready there), but they don't have stock and the chip is not being manufactured anymore. I was checking nxp datasheets and the MC33660 seems like a direct substitution, but they also stopped manufacturing that one and theres no stock either.
    Does anyone knows a substitution with current stock on mouser?
    Dec 2017
    Default Si9243AEY
    Hi! You may try to use SI9243AEY, but it is not pin2pin compatible, you must compare datasheets and rewire. After that should work well.
  3. The Following User Says Thank You to majer0 For This Useful Post:
    wokcz (22nd December, 2017)
    Member amor89's Avatar
    Dec 2016
    hi if not take them here frankly for the price you break the head
    here is
    https://fr.aliexpress.com/item/10PCS...23e6230d126b-1
