Results 1 to 14 of 14
    May 2017
    Default Correct mileage chevrolet sail 2013
    hi...
    I need your help to correct mileage for chevrolet sail 2013
    current mileage 108 000 KM (Approximate)
    mileage needed 128 000 KM
    here is your file
  3. The Following User Says Thank You to nikz For This Useful Post:
    MYMN (25th September, 2017)
    May 2017
    nice job my friend.. its work ..thank you
    Dr. Zoidberg's Avatar
    Oct 2015
    Talca-Chile.
    Quote Originally Posted by MYMN View Post
    mate, file nikz showed 128113 km?, can you tell me this please?
  6. The Following User Says Thank You to Dr. Zoidberg For This Useful Post:
    May 2017
    Quote Originally Posted by Dr. Zoidberg View Post
    Yes that's right
    can you tell me with what software you read the dump?
  8. #6
    Oct 2015
    Talca-Chile.
    Yes that's right
    algo is easy, km/8.....
  9. #7
    Dufner
    Johnner's Avatar
    Éire
    No,its not Zoid...It's Ford algo,and it's mileage /128(In this case)....and then you have to work out the check nibble
  10. #8
    Oct 2015
    Talca-Chile.
    Quote Originally Posted by Johnner View Post
    yes mate, is the same algo, so, that would be 1000 km?
    00 7E FF E0 00 7E FF 61 00 7E FF 62 00 7E FF E3
    00 7E FF 64 00 7E FF E5 00 7E FF E6 00 7E FF 67
    00 7E FF 68 00 7E FF 49 00 7E FF 4A 00 7E FF CB
    00 7E FF 4C 00 7E FF CD 00 7E FF CE 00 7E FF 4F
    00 7E FF D0 00 7E FF 51 00 7E FF 52 00 7E FF D3
    00 7E FF 54 00 7E FF D5 00 7E FF D6 00 7E FF 57
    00 7E FF 58 00 7E FF D9 00 7E FF DA 00 7E FF 5B
    00 7E FF DC 00 7E FF 5D 00 7E FF 5E 00 7E FF DF
  11. The Following User Says Thank You to Dr. Zoidberg For This Useful Post:
    jomberykaso (27th September, 2017)
  12. #9
    yes =1000 !!!!!!!!!!!
  13. The Following User Says Thank You to nikz For This Useful Post:
    levisdj (25th September, 2017)
  14. #10
    May 2017
    Hello..
    after driving the car .. I have found that nothing works,( speedometer , fuel indicator ,,) everything is blocked ,,, I have written the original eeprom but same problem
    the mileage has changed but nothing works ...
    Any ideas???
  15. #11
    May 2017
    When reading the dump with xprog, I made a mistake ..i chose AMTEL>> AT24C08.. ,
    the correct choice was ST>>24/25XX08
    it can be the cause of the problem??
  16. #12
    I think the problem is harde and not soft
  17. #13
    xm3n's Avatar
    Jan 2017
    may be damanged EEPROM change and test ..
    if not you need a new dash
  18. #14
    Jun 2016
    your Dump is perfect so dont worry about it...
    i dont think the problem is ATMEL ST its manufacturer only the thing is that select proper number..
    it maybe cause of writing Error if after read and write verify is success then there is no problem with IC selection..
    or it maybe soldering problem or minor collision ...
  19. The Following User Says Thank You to talk2idris For This Useful Post:
    jomberykaso (13th April, 2018)
