here is your file
here is your file
MYMN (25th September, 2017)
nice job my friend.. its work ..thank you
yes mate, is the same algo, so, that would be 1000 km?
00 7E FF E0 00 7E FF 61 00 7E FF 62 00 7E FF E3
00 7E FF 64 00 7E FF E5 00 7E FF E6 00 7E FF 67
00 7E FF 68 00 7E FF 49 00 7E FF 4A 00 7E FF CB
00 7E FF 4C 00 7E FF CD 00 7E FF CE 00 7E FF 4F
00 7E FF D0 00 7E FF 51 00 7E FF 52 00 7E FF D3
00 7E FF 54 00 7E FF D5 00 7E FF D6 00 7E FF 57
00 7E FF 58 00 7E FF D9 00 7E FF DA 00 7E FF 5B
00 7E FF DC 00 7E FF 5D 00 7E FF 5E 00 7E FF DF
jomberykaso (27th September, 2017)
yes =1000 !!!!!!!!!!!
levisdj (25th September, 2017)
Hello..
after driving the car .. I have found that nothing works,( speedometer , fuel indicator ,,) everything is blocked ,,, I have written the original eeprom but same problem
the mileage has changed but nothing works ...
Any ideas???
When reading the dump with xprog, I made a mistake ..i chose AMTEL>> AT24C08.. ,
the correct choice was ST>>24/25XX08
it can be the cause of the problem??
I think the problem is harde and not soft
may be damanged EEPROM change and test ..
if not you need a new dash
your Dump is perfect so dont worry about it...
i dont think the problem is ATMEL ST its manufacturer only the thing is that select proper number..
it maybe cause of writing Error if after read and write verify is success then there is no problem with IC selection..
or it maybe soldering problem or minor collision ...
jomberykaso (13th April, 2018)
