Results 1 to 5 of 5
    Default BMW E46 2.0d 100KW DDE Errors 0281010205
    I have this DTC on this car. Car crank but no start. Someone before me touch flash and eeprom and I think thats corrupted. Can someone see if is a good files? Thanks!
    nickolasd's Avatar
    Nov 2015
    dtc 42 could be bad eeprom dumb or bad checksum after tuning, with bad eeprom checksum vehicle will not start. if you can't fix old files try to re flash dme with original files with KFP or ista
  3. The Following User Says Thank You to nickolasd For This Useful Post:
    audi333 (15th June, 2021)
    I dont have original files. Someone before me work on this car. I dont have kfp and ista.
    nickolasd's Avatar
    Nov 2015
    original files coming form SP-Daten, its a original bmw software update. use in combination with winKFP software and bmw diagnostic tool such as k-dcan adapter. so you will be able to overwrite you damaged files.
  6. The Following User Says Thank You to nickolasd For This Useful Post:
    Jul 2012
    Hello
    Please help me to fix the dump from eeprom 0281010205.
    I have an error code : "42 dde control module eeprom and configuration"
    The VP44 pump is new . The starter turns, but the car does not start
