Have problem programing 29f010 whit clone beeprog. I can read and erse ok (use plcc32-dip32 adapter), but when try program get this eror on 14%. If smeone have solution? Thanks
I try several flash 29f010, the same results cant write. Can willem programmer erse and write this flash successfully? Thanks
Hello.
The problem is your adapter and/or chip.
Must clean very well all pins.
Try write with MiniPro TL866.work very fine and fast.In kit with adapters you can find and adapter for PLCC32
Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
I tried to write PLCC32 SST 39SF010A with MiniPro, no succes, error right in the beginning. Do not have idea what is wrong ..
I think only solution is new empty flash
cleaner your adapter soket
