2016 Accord
Results 1 to 15 of 24
Thread: 2016 Accord
    ascrap2003's Avatar
    Sep 2016
    Texas
    Default 2016 Accord
    Any one have a good dump for a 2016 accord 4 door auto US model?
    was doing one and now dump is corrupt and mileage and trip blank cluster still works gauges etc seems better to take Cluster apart n remove c76 keep getting fail to verify data won't save complete dump a few bytes here and there change each time you read or write using USA prog voltage set at 3.1 to 3.5 Accord 2013 C76 option
    Had a issue Had a issue with my uploads so if you see one of my posts and need that dump let me know and I'll post it!
    ascrap2003's Avatar
    Sep 2016
    Texas
    There has to better tool like upa vvdi Carprog or something to read write via solder points or another approach
    epd1221's Avatar
    Nov 2011
    usa
    I've done it with jprog no problem . Haven't try with USA prog yet
  4. The Following User Says Thank You to epd1221 For This Useful Post:
    sagie (1st August, 2018)
    ascrap2003's Avatar
    Sep 2016
    Texas
    Quote Originally Posted by epd1221 View Post
    How many have you done? 2013-2016? I did one before this gave me hell but it programmed
    after about 10 tries this one not so easy. Im
    wondering if the 2016 circuits are the same as 2013? Does anyone know if I can just use a 2013-14 dump?
    XmoDDeR's Avatar
    Mar 2011
    putting salt on leeches, one grain at a time!
    many different builds on that dash? writing u may have more or may have less..... but either way wont be correct
    Reading is fundamental, asking is easy............................
  7. The Following User Says Thank You to XmoDDeR For This Useful Post:
  8. #6
    ascrap2003's Avatar
    Sep 2016
    Texas
    Clusters had a dump posted on here 4K anyway keep in mind my car was a 2016 EX Sedan Auto btw took the cluster completely apart and desoldered tssop was then able to read and write at will. I'm convinced smelecom is not the tool for this cluster via solder points!
  9. #7
    ascrap2003's Avatar
    Sep 2016
    Texas
    Gonna give the next one a try with kynar wire and smelecom but gonna read and save dump with VVDI and Carprog first.
  10. #8
    XmoDDeR's Avatar
    Mar 2011
    ive done many a time with smele , so far ive done 22 accords maybe more no issues
  11. #9
    XmoDDeR's Avatar
    Mar 2011
    have fun with the needles
  12. The Following User Says Thank You to XmoDDeR For This Useful Post:
    MileageAudit5 (1st April, 2021)
  13. #10
    ascrap2003's Avatar
    Sep 2016
    Texas
    Quote Originally Posted by XmoDDeR View Post
    I think your just lucky, I cleaned pads with alcohol and applied flux, tinned fresh wire, soldered wires to board, used magnified glasses to see if solder points had shorts/bridges etc., read dump, save dump, edit dump, write dump. Bammmm!!!! Shit hits the fan!!
  14. #11
    lwood's Avatar
    city of angels
    Quote Originally Posted by ascrap2003 View Post
    post your part# i will post a dump for you.
    DON'T JUST SAY PRESS IT.....
  15. The Following User Says Thank You to lwood For This Useful Post:
    ascrap2003 (30th September, 2017)
  16. #12
    ascrap2003's Avatar
    Sep 2016
    Texas
    all ready taken care of but would love any 2013+ accord dumps you may have to save in case of future issues.
  17. #13
    lwood's Avatar
    city of angels
    just a couple.
  18. The Following 3 Users Say Thank You to lwood For This Useful Post:
    ascrap2003 (30th September, 2017), cklair (2nd October, 2017), sagie (1st August, 2018)
  19. #14
    XmoDDeR's Avatar
    Mar 2011
    X isa not lucky ........................X is skilled make that 25
  20. #15
    ascrap2003's Avatar
    Sep 2016
    Texas
    ? Sounds like someone is calling me out, i think the proccess can only maybe work for sure with kynar wire, inserted into those lil crummy contact points then while held into and not on those points solder adapter wires to kynar wires, then read and save dump mutiple times and compare dumps if they all match then edit & write. But i still see guys on here that have way more experience than me having issues and even saying jprog or other programmers better choice for this specific dash.
