Results 1 to 15 of 20
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Default need full bdm BMW edc16c31
    Hello mates, im in trouble. Maybe someone has full bdm readed Bmw e61 525d Edc16c31 HW: 0281012190 SW: 1037390905 SW upg.: 07812335.
    I readed total with kess , and when i was trying to write mod file, ecu bricked. Thanks and rep in advance!
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
    johak's Avatar
    usually kess makes the wrong checksum
    you can read ecu by bdm and fix it with winols
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    I made cs with winols before writing
    johak's Avatar
    of course, but when writing kess makes the wrong checksum
    johak's Avatar
    this is not a problem
    can be corrected with bdm
    I've had this problem several times
    if you want post here your original file read with kess and the file read with bdm
    dominik.m's Avatar
    Jun 2009
    POLAND
    Files for You. Full.
  7. The Following 4 Users Say Thank You to dominik.m For This Useful Post:
    aHmEX (17th February, 2022), daviromeral (23rd February, 2018), Ignasvw (2nd October, 2017), nizarben (10th November, 2018)
    Nov 2015
    Default bdm file
    hello master any one can split my bdm file i want eeprom file,thank u in advace
    Sep 2011
    ME PUEDES PASAR PASWORD GRACIAS.
  10. #9
    Sep 2011
    [QUOTE = dominik.m; 3112283] Archivos para usted. Completo. [/ QUOTE]
    PASA PASWORD FILE THANKS.
  11. #10
    Jan 2018
    Original file here, read-out with Kess V2, Kline
  12. The Following User Says Thank You to morfen94 For This Useful Post:
    Gery (20th January, 2021)
  13. #11
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Use always Fgtech for BMW! Fgtech also write EDC17cp02/06 with tricore. When not done it give error message and you can write ori back.
    Kess do wrong checksum for BMW and ecu bricke sometimes..
    FGtech clone also works good for this ecu.
    Regards,
    Verstuurd vanaf mijn SM-G955F met Tapatalk
    Sedat Garip
    Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
    Diesel + petrol All cars
    Manual Adblue dpf egr Opf tested working solutions
    Belgium
    With Kind Regards,
    Don't forget hit thank button if i helped.
  14. The Following User Says Thank You to sdtsedat For This Useful Post:
    user202 (31st July, 2020)
  15. #12
    Mar 2016
    Sweden
    Quote Originally Posted by Ignasvw View Post
    if you still need a file BDM BMW_E60-E61_525D_2005_Turbo-Diesel___130.2KWKW_Bosch_0281012190_07812335_39090 5_5F80.Original
  16. #13
    Nov 2019
    hi this files are damaged cant open. is anyone have a good files
  17. #14
    Nov 2019
    hi can u share a password for this file thanks
  18. #15
    Nov 2019
    Quote Originally Posted by dominik.m View Post
