dump bad
read the eeprom as c76
hello folks
Here I have a Jeep Wrangler 2008 in which I have read the eeprom dash thru obd thru dump tool. didn't want to connect thru the odo option.
dash has 58xxx miles I need 49XXX miles
seems like the right read bc i have compared with other files on here. thanks
dump bad
mojomojo (9th March, 2018)
Problem is you read the C76 only half (like a C66). Dataset should have size 0x400
nikz was faster
jomberykaso (19th October, 2017)
I thought it was the full dump because I had compared it with other dumps in this forum can someone provide me with the address line and the cold string for 50000 miles
option on fvdi to read dash dump through one thats how I read...will be removing cluster
Can someone provide me with the address line and string code for 50,000 miles? Thank you
here is the what I believe is the right dump 49,500 miles will be great
mojomojo (19th October, 2017)
, after trying to do research on the dash forum you were the one who I expected to help me you seem to be very helpful to everyone here I just want to thank you very much for the attempt but I had something by borrowing a USA prog from a friend of mine about an hour ago
It is ok mate.
