Results 1 to 2 of 2
    Rtronics's Avatar
    Dec 2009
    Australia
    Default toyota renesas 1725 boot mode
    hi, anyone know how to connect this board into boot mode.
    I tried connection between cpt1 and cpt2 not work. with short and without short. also if there is any 0 ohm resistor that needs to be removed I cant see which one.
    2016 hilux renesas 1725
    Failure is success, if we learn from it......
    Greetings from down under..... ( Australia )
    Brayn's Avatar
    Oct 2015
    Colombo
    UART write no need remove 0 ohms resistor. as your images and details you use CPT. if you use cpt please find clear file and write via UART
