Page 3 of 3 FirstFirst 123
Results 31 to 39 of 39
Thread: Clio 4 abs
  1. #31
    Already did.its same like in post 15#
  2. #32
    Is it possible to write in dash d-flash or p-flash blocking abs info
  3. #33
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by xpto View Post
    With smok via obd yes or can blocker in dash
    But trip counter probably wont count up after
  4. #34
    Im stuck with this car...
  5. #35
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    use blocker in dash
  6. #36
    Isnt any other way to make abs?what appen if i use other dump from other abs?
  7. #37
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Wont work you will just dig the hole deeper that your already digging yourself into mate just put a blocker in advise the owner trip might not count up correctly if he's not happy with that just give him his car back before it ends up needing to go to dealer for repair.
  8. #38
    Mar 2017
    Colombia
    Modify mileage in abs and clusters,
    put both pieces in place.
    open ignition 10 sec after putting them on.
    Dash D-flash or eeprom
    Abs eeprom.
    if you have fvdi or other put in car to see other modules. some models have it in ecm.
    @jhonner gave you the solution in abs,are you sure to do well on dashboard?
    WINNER THE LOSER
  9. #39
    Yes im sure.tryed and confirmed again.dash does ok,i can see the mileage i want.but with modified dump in abs dash stays ok but give errors in abs and cant see the speed just --.with original dump in abs old mileage came back and no more errors.im not gonna waist more time in this car...
