Results 1 to 4 of 4
    Feb 2013
    Default problem usb xprog 5.5.1
    Hi!
    my xprog 5.5.1 clone, after one year does not recognize usb port
    can someone help me where is the problem
    thank you very much
    Mar 2017
    France
    hi
    try to desinstall and install the program again
    regards
    Nov 2009
    Usa
    Quote Originally Posted by flixuno View Post
    Hi!
    thank you very much
    first change your usb cable
    reinstall your softwear
    go to enviremement chose the exact port
    if not send me in pm
    i will give you how you can repair your xprog
    Feb 2013
    is solved
    use new driver and OK
    here driver without pass
    If it helps you thanks and reputation
