Help choosing eeprom programmer
Results 1 to 7 of 7
    Oct 2017
    Norway
    Default Help choosing eeprom programmer
    I cant seem to be able post in the Airbag section of this forum, so trying here instead.
    I have this MRSZ3 Airbag Control Module which has among other errors, the 240 Internal Error faultcode.
    I do think i know how to do the clear on it, but my problem is what programmer to choose for this.
    I need a programmer cheapest possible since i will only use it for the MRSZ3 and possible MRSZ4.
    The MRSZ3 module i need to clear is the 65.77.6900727 Temic - 68HC912B32 which is prone to get this error.
    As i said i need help to choose the simplest Ebay choice (ie lowest software version) which can do this job for me.
    Hope someone can guide me to exactly what i should buy for this purpose
    Thanks in advance!
    Nov 2009
    Oct 2017
    Norway
    Thanks, yes i've seen Carprog, but which version can i buy which will work on that specific on board only controller? Also an important thing i wonder...the clear files (BIN), can i use a file saved through let say xprog and write it with Carprog? The choice is between CARPROG, XPROG and UPA, but which to recommend?
    electronistul21's Avatar
    Nov 2011
    galati,romania
    with xprog you have more chances
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
    Aug 2016
    i agree with you xprog is good
    narkeleptk's Avatar
    May 2017
    USA
    original xprog is great tool.
    May 2010
    Quote Originally Posted by xracer View Post
    Thanks in advance!
    Original UPA is a must before you buy anything else.
  8. The Following User Says Thank You to joemajdalani For This Useful Post:
    nenadgorgi (12th October, 2017)
