Buy key on your lokal dealer schop and program with bsi
I think it's same from 2008-
You may have the pincode to procedur the programing
What is the key programming process in this modell? (Obviously i need the pin code)
Do i have to preprogramm the key with the BSI data like the older modells (like 500, Bravo..etc) when is use this kind of ID46 keyless key ?
I found it in both european and chinese webshops but unfortunately i can't find more info (tango and miraclone only support the previous years)
thx
Be allways Thankfull!
jodge (10th October, 2017)
You mean the local official fiat dealer? They don't sell keys without programming in my country.
One more question when you bought your key it's a general fiat key from the shelf or they ordered and linked to the VIN or something?
thx
You should be able to reprogram used key fob. This is possible for sure in case of Dodge Journey and Fiat Freemont is like the same. You will need pin code also and everything can be done via OBD with MVP Pro, not sure other devices. Maybe SKP-900, X100 pro can handle this also.
jodge (11th October, 2017)
HeXeN (23rd February, 2020)
doubt...
https://www.dropbox.com/s/5p78rfl89v...t_pin.jpg?dl=0
just close the annoying popup "no thanks...blabla"
